Small port vs Large port head
Bicknacre, Essex
I've tried searching for this but I never have any luck with the search option for some reason.
Would someone be able to tell me the size difference between a small port and large port head, and how much extra the large flows.
Also what are the pros and cons of going from a small port to large?
On a standard engine its not really worth it. The small port head flows enough for the standard turbo, and gives better low down torque etc, which is why Audi fitted them.
If your planning on fitting a larger turbo, then its worth it, as the stock head starts becoming restrictive after 300hp.
Also the inlet manifold is small port as the S3 never came with a large port manifold, so you then have to go from a small port manifold to large port head, as this happens the air speed drops but volume increases. Which as stated isn't good for low down torque unless u have a big bhp setup.
wellys goes all right with its largeport
remembering audi's design criteria was 225bhp tops
modded cars, remapped with mods... Does this still apply?
I will be hybridding it soon so will be aiming for the same sort of power as Welly.
Does anyone know the actual dimensions of the large port and flow rate?
I'm gonna stay small port and go hybrid, like Steve, if that doesn't come up near Welly's I'll think about a big port head, but, I reckon small port should see a hybrid reach good figures.
lol, my old 145000 mile bus become the new hybrid benchmark...
It's not just about the head in all fairness, it's also about all the other flow related mods that help out in general. The thing has a colossal cooler, big pipework to fill, and the large port head as well.
Ideally I think people looking for the hybrid should be aiming to try and keep the boost at sensible levels personally. Tried and tested.
Does anyone know the width n height of the inlet ports as I've found a head but the owner doesn't know much about it but said the inlet port is about 55mm x 25mm.
What engine code is the head from?
<tuffty/>
<tuffty/>
Reactions: xpoweruk and Roadtrain
Reactions: AdzA3AGU
Thanks for the info guys, the head was a large port then. It didn't have an engine code on it for some reason.
If I got a bare large port head, could I transfer all the parts from my small port over to it?
Think you got to ask yourself what you want from your engine. Runinning a large head will shift your torque curve over a bit giving lower low end torque but give you better flow at high engine speed as it wont choke as soon as a small port head. Bigger isn't alway best.
Ye, as far as I know everything is transferable
Well he has another bare large port head which apparently hasn't got many miles on it and he wants £100 plus £15 p+p for it. Wondering if that's a good price, the brand new head with cams went for £165 on the bay.
Reactions: Gary_808
Why BAM (225 PS )has small port intake, instead AGU (150 PS) has large one? Thank you.
All the later engines after the AGU was stopped being produced are small port... it increases low down torque...
<tuffty/>
Reactions: Roadtrain
your 300bhp it becomeing a restriction number is way too low.
From what I've seen and run smallport is the right size for up to 400-450bhp for optimum torque.... there after largeport will flow more overall but you will loose some torque onset at the same time.
<tuffty/>
Ok thank you. This is because a "narrow" intake be of use for a turbo engine (instead aspirated one)?
Reactions: stevie e
not really... smaller intake increase airspeed and subsequently cylinder fill rate to improve torque... this is the same on both turbo and NA engine... laws of physics and all that
<tuffty/>
710
10
2K
7
13
HTC
