EM TuningAH Fabrications
Results 1 to 14 of 14
    devan's Avatar
    Jun 2010
    118
    Is my boost getting dumped?
    Hi, just wandering if the ECU is designed so that when my BAM S3 is skidding, the boost gets dumped?
    Just asking this because it seems everytime I go around a corner/roundabout and im giving it some, and the car skids slightly, the car seems to bog-down, like the boost has gone.
    Cheers,
    Ash.
    _____________________________________2010 Audi A5 Sportback S-Line ____________________________________
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    The ESP will activate the N249 valve that will dump boost to stop you getting out of shape. The best solution is to turn off the esp
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    is turning the ESP off enough.? or N249 delete required, which I don't fancy?
    N75j better?
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    I think some one told me that even with the esp turned off the car can take power away from you and the only way around it is the N249 delete. Not brave enough here either. lol.
    Westy's Avatar
    Dec 2008
    17,280
    Turning off the ESP will not completely eliminate the N249 boost dump but makes it a lot better. I've been running a bypassed N249 for over a year now with no problems.
    S3 Build Thread
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    Yer N249 bypass is easy peasy, me and friend did it hardly any mechanical knowledge and it took about 40 minutes.
    Car felt instantly smoother and more responsive, worthwhile in my opinion
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Nothing wrong with doing the N249 bypass. I've done that and always drive with ESP off, no problems here either.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Is there a how to on this N249 bypass? And what exactly is the reason for it?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by finesse View Post
    ...N75j better?
    than what mate?
    <tuffty/>
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by tufftybloke View Post
    than what mate?
    <tuffty/>
    in regards to holding booost?
    Aug 2010
    Dumfries, Tartan-land
    203
    If you cant drive your car without ESP on, you cant drive!
    1998 Audi A3 1.8T Sport (AGU) - Remap, Apexi CAI, Scorpion CAT back, 3" downpipe/Decat, Coilovers, 18" RS4's
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Wrong context here mate... ESP/ECU controlling boost to stop you going into a hedge... changing the N75 won't do anything... going N249 bypass 'should' help but sorta defeats the object and ESP won't be as effective... I always turn mine off as it works fine on a std car but is a little wiggy on a mapped car (probably what the OP is experiencing) as the difference between 'mapped' boost and the ECU's normal cut off is greater (actuator pressure) so you drop in power will be more noticable...
    N75J is a waste of time on an S3 and mostly pointless on an A3 unless its an AGU without a map sensor...
    <tuffty/>
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    <tuffty/>
