Results 1 to 7 of 7
    Lancaster
    1,623
    Engine temps - Vagcom vs Dash
    Our A3 TDI the temp gauge on the dash is wild. I'm pretty sure the dash is naff so i can't trust what that says.
    I took it out earlier, temp from the vents were enough to melt tar off the road. But Vagcom reckoned it was only 64 degrees.
    I've changed the green sensor in the water pipe. Is there another sensor somewhere?
    To do: None yet.
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    I know the s3's also have a temp sender unit, which is what tells the dash the temp.
    Could be the same on yours.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Theres one sensor that signal both the dash and the ECU.
    What was the dash saying when VCDS was saying 64?
    TD5 Land Rover Defender build
    Lancaster
    1,623
    Around 90-100ish
    To do: None yet.
    "Stick a V8 in it!"
    14,900
    The dash usually sits at exactly 90c when the engine is in its normal range of operation, (ie 80-100ish)
    Lancaster
    1,623
    I've had it working before, but then it started playing up again. I just wondered if it was a different sensor.
    To do: None yet.
    S3KO4's Avatar
    Aug 2009
    London
    850
    option 49 on the CC shows the correct temp, don't need vagcom for that.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
