Bilstien B8's if you are feeling flush with either Eibach Pro, Apex or H&R springs... cheaper alternatives are available but never used or have experience of any others tbh... B8's are quite simply brilliant...
And fronts S3 shocks won't work on A3's quattro or not, the S3 has camber adjustment and I think it's slightly wider also, so different suspension up front basically.
....And fronts S3 shocks won't work on A3's quattro or not, the S3 has camber adjustment and I think it's slightly wider also, so different suspension up front basically.
