Volks AutosChris Nott
Results 1 to 13 of 13
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Quick question while the bonnet is open!
    What diameter of hose can i use for the actuator to N75 connection?
    I'm just giving all the hoses a once over to try and hunt any splits.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    shanejess
    4mm
    Westy's Avatar
    Dec 2008
    17,273
    are you 100% sure? It looks bigger than 4mm!
    S3 Build Thread
    From Show... to GO
    Nov 2010
    Stafford
    436
    silicone stretches, ive used some 3mm silicone on a 6mm fitting before
    shanejess
    i told my wife this, she says you carnt put a pin were a nail has been.
    Westy's Avatar
    Dec 2008
    17,273
    honestly the 4mm hose i've got wont go over! anyway think i might have found a split elsewhere. cheers guys.
    S3 Build Thread
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Think 6mm should be good, I took out all the N249 stuff earlier and removing all the PVC pipework because I still havnt fitted my oil catch can! I was just getting to the N75 bits as it got dark so gave up but should be able to confirm tomorrow if the weathers alright!
    shanejess
    its 4mm, likes to be bathed in hot water 1st though.
    From Show... to GO
    Nov 2010
    Stafford
    436
    i fitted 3mm when doing the n249 bypass.
    ive got a few metres of 5mm and 8mm to do a few other bits
    id like to get rid of the SAI and PVC pipework, but dont have a clue where to start (and ive read the guides already lol)
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Yeah 3 or 4mm is fine for the N249 bypass (inlet manifold to the DV) but cant see that being the right size for the the N75 to the actuator think it needs to be just a bit bigger than that!?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It is more like 8mm, hes not doing the n249....
    Westy's Avatar
    Dec 2008
    17,273
    Correct Dave. I wanted to replace the hose that goes from the actuator to the N75 valve. I think the hose is ok but thought i'd change it while I was there.
    S3 Build Thread
    From Show... to GO
    Nov 2010
    Stafford
    436
    in that case yes its 8mm
