JMB RetrofitsVolks Autos
Results 1 to 15 of 15
Thread: gearbox oil
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    gearbox oil
    just about to go and buy gearbox oil for the s3, anybody know how much it takes to fill from bone dry, inlcuding transfer box? id imagine about 3ltr?
    and im right in thinking 75w90?
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    2.6 litres mate and yes its 75w90, i replaced mine with Motul Gear 300 and would defo recomend it made a good improvement to gearbox feel.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    thanks steve
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    I thought it was just over 3litres if you drained the transfer box also.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    I drained both and still have oil left in my third 1 litre bottle after filling it back up mate, so defo not over 3 litres.
    Sold - 2002 S3
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Thanks for that. So you just drained both and filled both through the one hole on the side of the gearbox. Audi do say it holds 2.6ltrs but dont know if that includes the transfer box
    I heard you needed to drain them both them fill till the fluid starts coming back out of the filler hole. Drive a bit, then fill even more because the fluid doesnt circulate to the transfer box without the wheels moving, not sure if its correct but got it from someone on here. Would be much easier if I can just drain both and fill and thats that.
    For sale
    PM for info.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,466
    How do you drain it?
    Don't forget a new washer for the plug
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Aug 2010
    bradford
    1,252
    i would not mind doing mine where can i get all part from and how much rufly for the lot to do the job
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Quote Originally Posted by S3 Nattie View Post
    Yes mate drain both, one drain plug on gearbox and one on transfer box, then fill up till fluid starts to come back out of filler hole(make sure car is level). Make sure you undo the fill plug first before draining(that way if its seized in your not stuck with a car with no gearbox oil). The gearbox itself takes 2.3l and the transfer box takes 0.3l. The gears inside the box transfer the oil to the transfer box, You need to refil the gearbox then the gear needs rotating to fill the transfer box, i did mine with clutch change so had car up on four axle stands so was able to put it in gear and drive it with wheels off the floor for a few minutes then top it up to ensure transfer box was full.
    Sold - 2002 S3
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Cheers for that, great help Steve
    For sale
    PM for info.
    From Show... to GO
    Nov 2010
    Stafford
    436
    good help steve, may do mine this week, ive only had the car a few months, but am slowly changing everything i can
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Is this Motul gearbox oil still the oil of choice people?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,431
    Westy, have a look in here see if you can get oil at good price.
    http://www.audi-sport.net/vb/group-b...ml#post1502103
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Searched for this thread. I changed my gearbox oil a while ago. I was advised that Part-Synthetic was fine.
    Halfords | Castrol Driveline Syntrax Universal 1L
    I have seen the above profuct and after seeing how much better the car felt with Castrol 5w30 in the engine, is this Castrol Driveline any good?
    And just to be sure, the FWD obviously don;t havea transfer box (well I would assume lol); what amount of oil does the FWD need?
    Cheers!
    Kristian
    No longer an Audi driver...
    Oct 2010
    Hampshire
    294
    There's a guide if you follow a couple of links....
    gear oil change???
