Chris NottSky Insurance
Results 1 to 8 of 8
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    small cracks on head
    so Ive removed the head off the s3 to replace the turbo and on inspection I've noticed a couple of cracks between some of the valve seats and I'm wondering if the head is usable or should I be getting a new head?
    thanks mike
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    Jan 2009
    West London
    269
    Hi Mike- you can get some new valve seats inserted. Take the head to a cylinder head machinist and get them to look it over and give you a quote. Worth taking it to someone around your area that deals with cylinder heads as if it is just a few valve seats then it shouldn't cost much.
    Andy
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Anything like this?
    Since the head is off, might aswell get it pressure tested before you put it back on
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    andy it's not the valve seats it the material between them.
    and Sandip it's like the bit between the 2 valves seats
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Quote Originally Posted by Mpathe View Post
    pressure test would rule out any leaks or you could get a large port instead
    beachbuggy's Avatar
    Surrey
    1,727
    AMK or APY?
    If it's an AMK then I would get it chk'd
    beachbuggy's Avatar
    Surrey
    1,727
    Just to add, if it's an APY not saying you don't need to get it chk'd, I'd just be more worried if it's an AMK.
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    it's an apy if it makes a difference
