Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    London
    160
    Angry k-line 1 short to ground & does not connect to check fault codes????
    Hello people was woundering if anyone has had this problem?
    Its not a the stereo system as it a factory fitted one and not a after market one!!!
    But i have disconected it to elimanate it and no joy!!
    I have tryed many other diagnostic tools and they dont connect also so its a fault with my car not the tool i have.
    So when i vag-com it it does not connect and when i do a port test and it shows k-line 1 short to ground!!
    All your help would be greatfull
    Thanks.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Maybe it had an after market one fitted before you bought the car and the previous owner didn't refit the factory stereo properly? is this a recent problem? have you been able to scan the can before this happened?
    Have you had any work done to the car recently?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Using the power of google (useful tool), there are a few posts suggesting you need to unplug the various modules one at a time to eliminate a rouge one... how you do this is a little beyond my knowledge but there is a wiring diagram pdf that Welly posted up so have a search and see if that can help... it would seem that a control module could be causing this... one link from google suggested the ABS controller... this can be unplugged from under the bonnet...
    Can't really suggest much else as it seems like a fairly laborious job to go through testing everything...
    Good luck...
    <tuffty/>
    London
    160
    thanks for the reply tuffy
    nah mate iv had the car since 2005 and it has never had the system changed.
    i have had no work done to it and its always connected up right away with out any problems
    were are the modules located?as i shall dissconect one by one to see were the problem lies.i belive it can not be the engine ecu as it will not strart otherwise!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    The 'modules' will be located all around the car IIRC... from what I have read from some of the google results the connectors culminate in the footwell behind the kick panels on some Audi's but whether thats the case on an S3 I don't know... would kinda make sense as all roads lead to Rome so to speak and in this case the OBD diag socket where the K-Line can be interrogated...
    Like I said, have a look for the thread Welly posted with the links to the PDF's as that will be a good start and you may be able to trace the K-Line back from the OBD socket to somewhere plausible for all the module com lines to connect up...
    May also be worth posting the question on the VCDS forum here on ASN
    <tuffty/>
    London
    160
    Thumbs up
    kool tuffy
    thanks for your help
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Another possible solution... have a look at the diag socket and make sure it has all the pins sticking out.... i.e somebody rough has come along and tried to forcefully align the socket???
    London
    160
    socket is all in good shape mate!!!
    Optimum Tuning's Avatar
    www.optimumtuning.co.uk
    Nov 2010
    37
    Before starting to disconnect modules I would firstly check the fuse to the 16pin obd connector. It should have a designated fuse for this - Probably not the cause but rule this out first. Check all others at the same time for good measure then move on. Next I would check obvious connectors behind instrument panel , ABS module etc etc for corrosion or damaged pins .You really need some wiring diagrams first before you start probing into circuits to do drop tests.
    2001 S3 8L, CR Turbos hybrid k04, Forge DV, silicone TIP,BBS LM reps.
    London
    160
    thanks mate
    i tryed looking for the wiring diagrams but cant find any.any one have any??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by S3SYD View Post
    thanks mate
    Seek and you will find :D
    Audi A3/S3 Workshop Manuals
    <tuffty/>
    London
    160
    Thumbs up
    Thanks tuffy
    your a star!!!!
