Monster MotorsportVolks Autos
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Sudden clutch biting point change
    Chaps,
    Looking for advice on a curious one with my S3 the last few weeks.
    I've noticed that the biting point has shifted very high on my clutch the last week or so. It used to be quite low before. It does not seem to be slipping, but I'm concerned it might be on it's way out. Had a new clutch, master & slave cylinder just over 1 year/10k ago so will be upset if another Ł7-800 bill for replacement if coming my way.
    I did have a seized rear caliper replaced about a month ago, and the brake fluid was changed as well. The brakes are as sharp as ever, so I'm confident the brakes were bled properly. I would have though air in the clutch system would have dropped the biting point lower rather than higher.
    Any suggestions welcome...
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    beachbuggy's Avatar
    Surrey
    1,727
    Is it high on both engaging and disengaging?
    I would first of all get it all bled again. You'd have to be really unlucky for it to go that quickly.
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Yeah. It is always high. I'll try to get it bled this weekend...
    I did have a minor oil leak from the VVT module before Xmas, but I'd be suprised if it was sufficient to leak into the bell housing.
    Cheers,
    Alistair
    Arnold Rimmer, 1988
