Badger5Volks Autos
Results 1 to 32 of 32
Thread: Haldex help
    swatchuk's Avatar
    Nov 2008
    208
    Haldex help
    basically i only have 2 wheel drive at the moment and the traction control light is on the dash all the time. fault code is 01324 control module for all wheel drive, j492 no comunication.
    Ive done a search and found a couple of things. First off i cheacked the conection plugs and all are in good condition. i cleaned them anyway.
    Next one was the earth strap. I cant find one on my car at all and there are no signs of one being there. Can any one tell me if all s3s are ment to have one??
    Oh the fuse is fine too.
    Other than that is it the haldex controller itself?
    Any help would be appreciated. Thanks in advance
    Mark
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    What year is your S3 and have you serviced the Haldex recently?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Last time I saw this fault, the loom plug for the haldex had gone bad, all corroded inside and was causing the problem.
    Cut the loom plug off, and soldered the wires instead. Problem solved.
    Homer Simpson
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    Said the man (another one!) who is obviously handy with the soldering iron !
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Quote Originally Posted by thegoal007 View Post
    Whats with u and the word soldering iron today
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Mines a 2001 and it doesn't have the earth strap thinks it's pre face lift or something not sure. But I know not all have them. My Haldx isn't working either. I even added a earth strap on mine didn't make a difference. Just don't work and with the power ive got 1st 2nd and 3rd gear spins just can't get the power down.
    Quote Originally Posted by swatchuk View Post
    Mark
    Nogaro Blue 2001 S3 Quattro, Cream leather interior. Miltek Cat back, Induction kit, KO4 Hybrid Turbo, Chipped Remap, Power Boost Valve, Forge RC DV, Compbrake Racing 4 Pot Calipers with 2piece 350x32mm Conversion Front, 2 piece 330x20mm Compbrake Conversion on Back, Discs are Powervane Racing Rotors Gas slotted and internally veined. Hawk Hps Pads, Goodridge Braided lines to Calipers. Bose Symphony sound system. Compbrake Quickshift and side shift. Big thanks to www.Vagperformance.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Quote Originally Posted by Kingston View Post
    x3
    AudiS3Quattro's Avatar
    Jan 2009
    201
    I have the exact same problem, took it to audi and they said it was my haldex control unit. the quoted me 1200 for a new one but am goin to get the haldex performance controller brand new for 700 ish, no brainer really! cant wait to get it, so i can finally get the power down!
    2003 BAM Nogaro Blue S3, Revo Stage 2, Approx 270BHP Miltek Exhaust With THS De-cat, Neuspeed P-Flow, Forge Split-R DV, 19" Rail Daytona's 9'' Rears, 8'' Front, Stretched Tyres, Euro Look, 20mm H&R Rear Wheel Spacers, 10mm Front Wheel Spacers, H&R Springs, Chrome Mirrors, Piano Black Dash, Black Recaro Heated Leather, Xenon Headlights, LOW and WIDE!
    swatchuk's Avatar
    Nov 2008
    208
    Well i think im going to have to get another unit from somewere. Does anybody know if when i replace the haldex controller, will it need programing at all. Or will it just plug in and work??
    Cheers, Mark
    Jan 2009
    201
    quote from thettshop.com haldex performance controller!
    'The HPP kit comes complete with the plugs (two) that fit right into the OEM connectors, replacement bolts and a gasket for a simple clean installation. No additional fluid is required. Completely Plug -N- Play.''
    Parts, Accessories, Styling and Performance Tuning for your Audi TT Coupe or TT Roadster
    Jan 2009
    201
    We should see if we can get a group buy sorted! I dont know how to go about it though!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    Quote Originally Posted by AudiS3Quattro View Post
    Goodluck with this, I've seen a few attempts, and they end up crash and burning!
    steve
    Sep 2007
    Elgin, Morayshire
    81
    I had the same problem with mine. I ended up buying the haldex performance unit. It was certainly the best choice. It drastically improves the power you can put down in 1 st gear and you notice faster throttle response throughout the other gears. And subject to what people might say it doesnt turn your car into a drifter in the bends as long as you go in and oot under control. Its easy to fit and comes complete with instructions. Be sure to check your haldex oil level after fitting it. If its low then look at either topping it up, or perhaps replacing the filter and fluid. If this hasn't been carried out at the regular scheduled intervals, this can throw your haldex out of sync resulting in the problem that you have now.
    Feb 2011
    southampton
    229
    so the controller is main cause for 01324 vagcom code and if you get a new one it will work again
    audi s3 2001 amk 210bhp, forge 007p
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    Quote Originally Posted by jojo View Post
    e.g. Any one interested in a Haldex ECU upgrade group buy?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Feb 2011
    southampton
    229
    will a haldex controller for a audi tt fit my s3 are they the same as long as its gen 1 controller
    Feb 2011
    southampton
    229
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    49-00 - No Communications
    65535 - Internal Control Module Memory Error
    00-00 - -
    found this code in awd
    dose this mean the controller is knackered
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    check the plug for the controller. welly took one off and took it apart and it was corroded to death, re-wired it and it worked.
    just a possibility.
    and yes a tt controller should work.
    Feb 2011
    southampton
    229
    ok cheers mate will have a look can you remember what plug it was the one on the back of diff or haldex it self. also where did you get a new plug from
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    the plug that comes out the haldex controller, fairly big black thing. i havn't bought one, but welly cut it off a car he was working on, and took it apart and re-wired it, as it was all corroded. fixed it in his case.
    Feb 2011
    southampton
    229
    ok mate ill have to have a look mate cheers.. if it fixes it thats a good fix as the controllers are alot of money
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Well remembered that man.
    Bottom line, it's exposed to the elements - electrics and rain aren't friends. It's an easy job, and will only take 2 mins to check to be honest, I've got some photos somewhere, I'll have a look now.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Here we are:
    Homer Simpson
    Feb 2011
    southampton
    229
    so if i cut the plug off can i solder the wires together and heat shrink them together or even male and female spade connectors
    May 2011
    195
    Welly, where is this located and how do i check my oil etc etc
    Feb 2011
    southampton
    229
    its on the side of rear diff on driver side plugs into haldex when its in the air its easy to see
  28. #27
    May 2011
    195
    Cheers for that fella
  29. #28
    Feb 2011
    southampton
    229
    Quote Originally Posted by fossie View Post
    i take it yours is not working either..
  30. #29
    Feb 2011
    southampton
    229
    i got some contact cleaner today so will un plug it and give it a really good clean and see if i can get it to work..
  31. #30
    Feb 2011
    southampton
    229
    cleaned the connectors today and still wont work .. you can hear the pump working but no haldex i dont understand also the connectors was clean not corroded
  32. #31
    Mar 2013
    9
    Hi
    Was looking through old threads because my A3 3.2 quattro 2004 8PL has the esp light on and a specialist has told me its the haldex control unit.
    How was your car after the performance unit was fitted?
    Any advice appreciated.
    RC
  33. #32
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Hi mate.. Your car is an 8P so the newer model to this. Better to post In the 8P section as the Haldex is Gen 2 in the 8P. But like these lot, get it scanned for faults and work from there instead of shedding loads of money on a controller. Check the connections too.
