Sky InsuranceBadger5
Results 1 to 21 of 21
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Vag Com Code 16395
    Morning All,
    Scanned my car last night and this popped up has anyone seen this before.
    Address 01: Engine
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 13365
    1 Fault Found:
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Digging around Ross tech I get the explanation:
    16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    Possible Symptoms
    • Power Loss
    Possible Causes
    • Camshaft Adjustment Valve 1 (N205) faulty
    • Fuel Pump Relay (J17) faulty
    Possible Solutions
    • Check Camshaft Adjustment Valve 1 (N205)
    • Check Fuel Pump Relay (J17)
    Question I have is where is the Fuel Pump relay located?
    Also does anyone know how easy it is to change the N205 valve? - I have had a look around and searched but can find very little on the valve?
    shall I book her into the garage and get her looked at.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    N205 = VVT... assume yours is AMK or BAM?... does the engine sound rattly on idle?... make a bit of a rattling noise on first start?
    <tuffty/>
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    not that i've noticed to be honest matey, i'm always ears for this type of thing. the engine is my music.
    I'll go and start her up when im on my break with a mate and get him to start it while i got my head under the bonnet.
    270bhp 13.6 1/4 mile
    Dec 2010
    Asherville
    24
    Clear the fault and see if it comes back, sounds like cam timing or maybe the n205 plug is loose
    Silver 2001 Audi S3 quattro.
    GIAC, Samco TIP, catless mandrel bent 2.5'' 2 box exhaust, Aquamist WMI, SPEC stage 1 clutch, N249 bypass, Forge Spltr DV, Oil catch can, colder Bosch super 4 plugs. Has audio and cosmetics too
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    I've just been out and scanned the car the code hasn't come back. i will scan everyday for the next week to see if it comes back.
    how strange why would it of come up i the first place....
    Thanks for all the replys :-)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    Quote Originally Posted by S3 Baby View Post
    Is this the first time scanned for a while? I notice you started a thread a while back to do with the gasket under the VVT/tensioner... possibly a legacy code from then?
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It may have been an old code that has been fixed....
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    No i have scanned it many times since changing the gasket it maybe the first time this year.
    I have fitted my Oil Catch Can a couple of weeks ago but i can't see this bring the fault up.
    GeneralWest's Avatar
    Sep 2009
    Cambridgeshire
    168
    S3 Baby, I was just wondering whether you managed to find out what caused your fault code? I've just had the same fault code appear on my S3, accompanied by a low oil pressure warning on the dash.
    Now: 2001 S3 Nogaro Blue
    Then: 2000 S3 Black
    S3 Nattie's Avatar
    Quattro ist fĂĽr sissies
    May 2009
    Cardiff
    1,600
    This fault code come up because the oil pressure is low in the engine and as the VVT uses oil pressure to adjust itself, it cannot adjust if pressure if low. I had this code for ages and change so many things to get rid of the code, fault turned out to be a faulty VVT unit.
    Change your oil pick up pipe first as you got your low pressure light on and deleted the code. If it returns its likely your VVT is faulty.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    Sep 2009
    Cambridgeshire
    168
    Quote Originally Posted by S3 Nattie View Post
    ....fault turned out to be a faulty VVT unit.
    That's what I'm afraid of. I had the sump off 10k miles ago to clean the oil pickup pipe. I'm now changing the oil every 5k, so it shouldn't be that.
    The Rosstech site suggests checking the N205 valve and mechanical timing, which I guess means the VVT unit.
    How much did a new one set you back?
    Then: 2000 S3 Black
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Had the timing belt done recently??
    I had the exact same fault when my timing was out by 1 tooth
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Quote Originally Posted by GeneralWest View Post
    Its more than likely your pick up as you got the low oil pressure light on. Should clear once you have dropped the sump and cleaned/changed the oil pick up.
    I had a new VVT which started playing up when my cambelt went so just put my old original one back in and that got rid of the fault for me. There is 2 sides to this fault code 16395 and 16366, over advanced and over retarded and I was getting them both at different times so was to do with the VVT adjusting intermittently. Can get them from ebay for Ł140 I think I paid but I wouldnt worry about your VVT just yet. Pick up first.
    For sale
    PM for info.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by sandip View Post
    Yeah, that's a ***** when that happens :/.
    My mates was like it for ages.... which I built, and then couldn't arsed to sort... Did eventually and is OK now, but he must have driven it for 10K like it lol.
    Homer Simpson
    Sep 2009
    Cambridgeshire
    168
    No mate, belt was done 20k ago. Cheers for the suggestion though.
    Then: 2000 S3 Black
    Sep 2009
    Cambridgeshire
    168
    Cheers, guess I'll check out the pickup again.
    Then: 2000 S3 Black
    Sep 2009
    Cambridgeshire
    168
    My car is going into my mates workshop at the end of the week. We'll whip the sump off to double check the oil pickup and then connect up an oil pressure test gauge to see what readings we get.
    Sorry for the thread hijack BTW and thanks for the advice.
    Then: 2000 S3 Black
    Sep 2012
    Caracas, Venezuela
    45
    Follow ceS3r On Twitter Visit ceS3r's Instagram Channel
    <tuffty/>
    This code came into my S3 today.. My car does rattle on every cold startup, BAM engine.. What does this mean?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    Quote Originally Posted by ceS3r View Post
    Means the VVT tensioner is worn and needs replacing... I would advise using an OEM part only as the cheap copies are next to useless...
    <tuffty/>
    Sep 2012
    Caracas, Venezuela
    45
    <tuffty/>
    Thank you for reply, will do as soon as I can!
    Sep 2012
    Caracas, Venezuela
    45
    I believe this is the tensioner.. It is normal to be like this?
