Volks AutosEM Tuning
Results 1 to 14 of 14
    Jul 2010
    bristol
    647
    Power steering pump failure?
    Hey guys
    Just pulled into my road and as i turned into my space my steering went mega heavy and smoke came through the blower vents with a buning smell! Had a quick look and the aux belt is still intact so im guessing its the pump, is it a driveway job or am i best off putting it in a garage?
    Cheers in advance
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Its possibly the metal pipe that has gone, very open to the elements esp the bad winter we have had
    Jul 2010
    bristol
    647
    Which pipe is that mate? Down behind the passanger wheel?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    yes it goes down there then across the engine by the rad and back again, the other one is on the rack itself,
    if it is leaking by the passenger wheel it connects there to some rubber pipes
    fran-s3's Avatar
    1,090
    could be worse mine did this without the smoke... booked into a VAG specialist and it turns out it's my steering rack that's leaking power steering fluid... 4 hours labour plus a new rack! Gutted. Hoping my pump will be ok despite screeching like heck when it ran dry.
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    Ive just fitted a new pump on mine, but this was due to fun in the snow lol
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Not normally a pipe if there is smoke being produced. I know, I've cracked numerous PAS High pressure lines.
    Check the PAS reservoir for the fluid level to see if it's empty. If it is, fill with fluid and check for leaks.
    If no leaks, pump is likely.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by fran-s3 View Post
    Should be OK - mine has seen this a few times. It's not at it's best I admit now, but it has run dry 3 times...
    A bit noisy, but still works.
    Homer Simpson
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Yeah i was thinking it could have pissed all over the exhaust if it happened while he was driving
    Jul 2010
    bristol
    647
    exactly the pipe you said it was dave, what a ***** that is to get off! 40 for a new one and im back up and running but i think my pump has seen better days, its making a little squeeky noise on idle now, guessing from being run dry for a minute or two stupid pipe, cheers for the help again mate
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    No worries glad your sorted, they are a bit fiddly to get on and off 40, wasnt too bad....
    Chugger
    North Devon
    2,716
    The pumps are quite hardy. Mine ran for a while with low fluid because my cooler pipe also broke. Just make sure you keep checking the level as it will drop while air escapes. Also make sure you use correct fluid, apparently standard stuff is no good.
    57 A3 2.0 TDI Sportback (140)
    S3PEG's Avatar
    Bristol
    99
    Quote Originally Posted by sportstractor View Post
    What's the best fluid to use?
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Audi VW hydraulic CHF 202 ,
