Sky InsuranceChris Nott
Page 1 of 4 1234 LastLast
Results 1 to 40 of 143
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    VCDS logging suggestions on what to log.
    I'm planning on doing some logging this Saturday morning (if I can drag my lazy arse out of bed!) to try and diagnose a possible boost leak/failing MAF. When I get my toe down I can hear the turbo and it sounds like normal but the car seems to have lost the kick it had before.
    I plan to log the following blocks and wondered if anyone had any others to add to the list:
    - Block 1
    - Block 2 = MAF
    - Block 20
    - Block 31
    - Block 115 = Boost
    - Block 118 = N75 Cycle
    All of the above should give me an idea of boost, MAF, Fueling, rough power figure etc.
    If anyone has any other suggestions please post here.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Westy's Avatar
    Dec 2008
    17,156
    Thanks for that link Dave but I was more after peoples experiences of logging to diagnose power issues. I'm kind of hoping my MAF readings are low and by unplugging the MAF will confirm its the MAF. It's an easy fix then.
    S3 Build Thread
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    I am very much in the same boat, think my MAF has given up the ghost but was wondering how to confirm it with VCDS!?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    std 210/225 should read 180g/s and remapped 200-210g/s approx
    substantially less and its goosed
    also check (not log) block 032 and see what fuel trims are at (before erasing any faultcodes, as that also resets adaptions on 032)
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Westy's Avatar
    Dec 2008
    17,156
    Thanks Bill. How long do MAFs tend to last on a remapped car in your experience? My MAF is nearly 3 years old!
    S3 Build Thread
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Im not aware that my MAF has ever been changed lol! I had a peak of 138g/s this afternoon and thats after fitting Bills 3" TIP & a big old JR cone! think I will be giving audi a call then
    Westy's Avatar
    Dec 2008
    17,156
    JB have you got an S3, it looks like it from your pic? If you unplug the MAF and re-do your logging your car should use the default values of the ECU instead of the MAF reading (as its unplugged). If you've got a more powerful car, you know your MAF is fecked.
    This is a cool spreadsheet to use to get a rough power graph: http://www.ross-tech.net/vag-com/exa...0_Tutorial.xls
    S3 Build Thread
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Yeah its an AMK, I might give this a go in a minute then I have just ordered a MAF from audi anyway hopefully this will just confirm! Is there anything I should log whilst doing this?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    remembering back to the RR day we did... there was an S3 on that day which had barely over 100g/s from his MAF - it happens.. quite often
    bill@badger5.co.uk
    Westy's Avatar
    Dec 2008
    17,156
    I might unplug my MAF for the drive home to see if it feels any different!
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    Just logged my boost, MAF, and power on my way to get my exhaust fixed. Anyway I had a quick peek at the maf reading while logging and the max I saw was 188 on a stage 1 S3!!!! That might explain my lack of power. I'll have to check the boost readings when I'm home to see if there's a leak but somethings not right!
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    Went to Audi and got a new MAF which has made the car feel so smooth but something is still wrong as I'm getting the same reading on the new MAF! Heres the results of Blocks 2 (MAF), 115 (Boost), 120 (Power):
    Old MAF:
    MAF = 188g/s
    BHP = 244
    TRQ = 270lbft
    BOOST = 22PSI
    Unplugged MAF:
    MAF = N/A
    BHP = 245
    TRQ = 260lbft
    BOOST = 22PSI
    New MAF:
    MAF = 187g/s
    BHP = 229
    TRQ = 268lbft
    BOOST = 22PSI
    HELP! WTF is going on? If the MAF readings are that low with a new sensor and on a car that is holding 22PSI what else could the problem be??
    Any help appreciated.
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    Just noticed that this error is reocurring:
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    • Reduced power output
    • Limp mode
    Possible Causes
    • Boost Pressure too High
    • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    • Charger Pressure Control defective
      • VNT (variable nozzle turbo): nozzles stuck
    • Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    • Check Hoses/Pipes to/between Components
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check / Clean / Replace Charge Pressure Control
      • Check / Clean mechanism for variable nozzles
    I think i'll go away and log the N75 cycle and see if thats the culprit.
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    Right i'm going to log the N75 duty cycle this evening and just want to make sure i'm on the right track.
    From my understanding I should be logging block 118 along side 115 to show the boost as well as the N75. The N75 should hit around 96% to show spool up then wind back while it achieves its requested boost. Anyone else done N75 logging before?
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I dont think they go past 95% as a safety measure...irc
    Westy's Avatar
    Dec 2008
    17,156
    Ok I logged the N75 and it seems fine as it's peaking at 94.5%
    Soooooo, what could my problem be? What else would cause low MAF readings if the MAF is brand new? Small boost leak possibly?
    S3 Build Thread
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    1 . 002 115 119
    2. 032 (both values, when idling)
    Westy's Avatar
    Dec 2008
    17,156
    What's block 119? I have a file of 002, 115, & 118 to show MAF, Boost & N75
    What does block 032 show?
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    Also does anyone know what the "charge pressure control" is?
    The code above says to try the following:
    Possible Solutions
    - Check / Clean / Replace Charge Pressure Control
    S3 Build Thread
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by Westle View Post
    032 adaptations made because of vac leaks etc
    Boost pressure control
    Duty cycle boost pressure control valve vs Boost pressure before throttle valve
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Westy's Avatar
    Dec 2008
    17,156
    Thanks Finese but still doesn't explain what or where the charge pressure control is to clean or change it.
    I'll log 032 tomorrow and see whats occuring. Cheers
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Your maf reading are very similar to what i got a few months back, what map are you running?
    I had loads of leaks when i got 188g/s. Most of my pcv hoses were split plus my cylinder head was cracked
    Westy's Avatar
    Dec 2008
    17,156
    Quote Originally Posted by sandip View Post
    That's not what I want to hear! My PCV system was changed in the summer when I fitted my catch can, maybe there is a leak in my new system? I'm running a ChippedUK map from "Chip n spin".
    I logged block 32 as suggested above but not sure if it's the right block as it's showing Lambda 1.3% & -0.8%
    S3 Build Thread
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    results are fine
    Easiest way is to check block 032.
    There are two fields in the block, and both belong to fuel trims.
    Left hand one is short term adaption, right hand one is long term adaption. Left hand one is the one to look at in this instance.
    Make a note of these two figures. Reset the fault codes (even if there are none), as this will clear the fuel trim data back to 0% for both blocks.
    Then start the motor and log block 032. If the value in the left hand block steadily climbs to or past the 3-4% area, it's normally a good indication of a leak.
  28. #27
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Charge pressure control would be the actuator....
  29. #28
    Westy's Avatar
    Dec 2008
    17,156
    Ahhh nice one cheers. So the above is an indeication of leaks within the FRP if it is measuring fuel trim?
    So it looks like my next port of call will be PCV and boost hoses.
    S3 Build Thread
  30. #29
    Westy's Avatar
    Dec 2008
    17,156
    Any way of using VCDS to log what the actuator is doing? I'll try to post up my boost graph in a minute.
    S3 Build Thread
  31. #30
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    Quote Originally Posted by finesse View Post
    and other scenarios like maf under reading, and lambda correcting afr
    bill@badger5.co.uk
  32. #31
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    could try the hose from n75 to actuator, sometimes are loose on the actuator
  33. #32
    Westy's Avatar
    Dec 2008
    17,156
    Bill, If my boost readings seem fine, and so do my Lambda but my MAF (brand new) readings are low where would you start hunting for problems?
    S3 Build Thread
  34. #33
    Westy's Avatar
    Dec 2008
    17,156
    Ok here's my graph showing boost on the old MAF and the new MAF. The lines will be slightly different anyway as the runs were logged on 2 different stretches of road. As you can see the boost seems to tail off pretty quickly, could this be a tired actuator??
    S3 Build Thread
  35. #34
    S3KO4's Avatar
    Aug 2009
    London
    850
    I have logged the the above mentioned blocks:
    I have got the following:
    gs= 202
    BHP = 202/0.8 = 252
    torque= 325nm out of a possible of 435!
    psi= 23.3
    why is the torque down so much. I would have thought it would be near the 400 mark! and the bhp is down by 10
    test was done using 3rd gear with shell v-power, both oil and coolant temp were both 90C
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
  36. #35
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I would think the torque is enough.....maybe slightly down on the g/S readings...
  37. #36
    Westy's Avatar
    Dec 2008
    17,156
    Quote Originally Posted by S3KO4 View Post
    gs= 202
    BHP = 202/0.8 = 252
    psi= 23.3
    Put your torque figures into this spreadsheet to get lbft:
    You've got to remember that the readings are all from sensors and not a true representation of your actual Torque if you were to get on a RR.
    S3 Build Thread
  38. #37
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Unfortunately a lot of RR arnt true representations either....lol
  39. #38
    Westy's Avatar
    Dec 2008
    17,156
    haha very true.
    S3 Build Thread
  40. #39
    S3KO4's Avatar
    Aug 2009
    London
    850
    There is only one way to find out. a side by side drag race..
  41. #40
    S3KO4's Avatar
    Aug 2009
    London
    850
