Page 4 of 5 FirstFirst 12345 LastLast
Results 121 to 160 of 196
Like Tree3Likes
Thread: HOWTO: A must do mod - poly dog-bone mount!
  1. #121
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Mine's just arrived (Red). Will report back once I've fitted it along with Haldex blue and a new thermostat this weekend.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  3. #122
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    You won't believe the improvement it makes to the feel of the car, and for under £20. BARGAIN.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  4. #123
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Anyone got a nocking noise after fitting this?..when going over pot holes etc,
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
  5. #124
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    No mate. Maybe fitting the mount has highlighted another issue on your car?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  6. #125
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Are all 5 nuts/bolts correctly torqued?
    > S3 225 (03) - OEM+
    View: My S3 diary
  7. #126
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Its a nocking noise when i go over pot hole etc just from the drivers side.im gonna take it off again and torque all the nuts up and try then.im sure it has only started since i fitted it!.
  8. #127
    Westy's Avatar
    Dec 2008
    17,281
    It may have highlighted a weakness somewhere in your suspension. Could be bushes or ball joints.
    S3 Build Thread
  9. #128
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Nope mate ive done all that,i dont have a arb.i have new wishbones,new top mounts,new bearings etc and new coilovers!..i have just taken out the front coilover and the sharft has play so i put my old ones back in but still have the same problem!.
  10. #129
    Westy's Avatar
    Dec 2008
    17,281
    Hmmm bit strange.
    S3 Build Thread
  11. #130
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    Got my deisal dog mount I'll post how it is. Will be done with new top mounts , lowered 30+mm more and a TT arb
    CAR IS GONNA BE LOOKING SWEEEET :D
  12. #131
    Apr 2007
    98
    HEy, I changed my bush to the red diesel one......plus loads of other bits, ball joints, tie arms, full superpro front bush kit etc etc etc and then i got a knocking when pulling off, braking, turning, over bumps etc.....It was driving me MENTAL! Turns out that the rear engine mount is not supposed to be removed that often and being stretch bolts into aluminium they can wreak havoc with the threads in transmission.....Every time i removed the mount to look for the noise and the re torqued the bolts i was stripping a little more thread....it gave way on me last install......drove it to Midland VW and Jody heli-coiled it for me....knock has now gone.
    The middle 16mm bolt was swinging in the threads, causing the knock.....not that common but getting more so as everyone is changing bushes apparently.
    Can fault Midland VW top top garage, will defo be using them in the future.
    Be careful with those bolts boys.
    Audi S3 AMK
  13. #132
    Westy's Avatar
    Dec 2008
    17,281
    The audi technician I know actually advised me to use brand new bolts too. I haven't though.
    S3 Build Thread
  14. #133
    May 2011
    195
    Cheers for the links - just ordered mine
  15. #134
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Hmm aint sure if its the mount as it sounds like a clanging noise,something loose!..perhaps i should get some new bolts then i can cross that off if its that or not...maybe the coils hitting each other?..it is very low!
    One other thing,any other good mounts worth replacing/uprating?.
  16. #135
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    how much are the bolts?
  17. #136
    Westy's Avatar
    Dec 2008
    17,281
    Not too sure. Probably a good £3 each as they're quite hefty.
    S3 Build Thread
  18. #137
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    oh thats ok-ish. you think its worth buying them. dont think my dog mount has ever been changed tbh
  19. #138
    Mar 2010
    MILTON KEYNES
    108
    have fiited mine yet, glad i ordered the bolts as well though!
  20. #139
    Westy's Avatar
    Dec 2008
    17,281
    To be honest. Audi technicians will advise you to change most bolts when changing parts.
    S3 Build Thread
  21. #140
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by finesse View Post
    Just fitted the diesel mounts on the S3 : Awesome - Powerflex Front Engine Mount Dog Bone PFF85-420R - Golf Mk4 etc Diesel NEW
    No vibrations in cabin
    Power transmission feels solid and smooth & tight
    Gear changes not clunky or difficult or thumps in
    100% recommend this to everyone
    Old mounts looking ready for the bin :
    http://i55.tinypic.com/w16yj5.jpg
    http://i51.tinypic.com/349cv12.jpg
    Free large file hosting. Send big files the easy way!
  22. #141
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Dont surpose anyone has the part numbers for the bolts please?
  23. #142
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Quote Originally Posted by Westle View Post
    Including the wheels?
  24. #143
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    Yeh part numbers would be good
  25. #144
    Agric04's Avatar
    Feb 2011
    Grantham, Lincolnshire
    198
    Can also vouch for this being a good mod for the money.
    Awesome gti fitted mine on Friday and wow it makes a very noticeable difference. Would never have considered it had I not seen this thread so thanks guys.
    Current:
    2013 Audi A5 Coupe Black Edition 2.0 tdi 177 manual with t
    echnology pack, interior lighting, cruise control, heated seats.
    Past:
    2006 Mk5 VW Golf GT 2.0 tdi 170
    2001 8L Audi S3 1.8T
    1998 8L Audi A3 1.8T
    1996 Mk3 VW Golf Gti 2.0 8v
    1994 Mk3 VW Golf Gti 2.0 8v
    1986 Mk2 VW Golf driver 1.6
    1987 Vauxhaull Nova 1.0
  26. #145
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Can I get a thanks for everyone that found this useful then please haha
    S3Lol likes this.
    '01 AMK, completely standard except for the Ambient Lighting Pack.
  27. #146
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Mmmmm cheers Awesome
  28. #147
    Westy's Avatar
    Dec 2008
    17,281
    Stop posting pics and get under your car!
    S3 Build Thread
  29. #148
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Am posting this whilst under car
  30. #149
    Westy's Avatar
    Dec 2008
    17,281
    Quote Originally Posted by voorhees View Post
    Nice answer smart arse
    S3 Build Thread
  31. #150
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by SiGainey View Post
    ive give you a thanks seen as you havent got many......lol
  32. #151
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
  33. #152
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Bit of help if poss please just doing mine now undone all the bolts but one of the heads on the 13mm bolts decided to snap off, how can I get the mount of now? Is there threads on the mount hole which the bolt goes through what will stop it sliding off or can I just try pulling it off over the thread what's left??????
    IF IN DOUBT FLAT OUT---iF U AINT RUBBIN U AINT DUBBIN
  34. #153
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Pleeeeeeeese!
  35. #154
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    There's no threads in the mount that comes off, there's only threads in the subframe. This happened on mine, I eventually managed to pull the mount off through the repeated use of heat/plusgas/hammer and screwdriver! I think lots of heat was the key though....
    > S3 225 (03) - OEM+
    View: My S3 diary
  36. #155
    wayne1.8t's Avatar
    Aug 2009
    lancashire
    150
    Thanks mate 20min job turned into alldayer.
  37. #156
    Jul 2009
    Cambridgeshire, United Kingdom
    427
    has anyone bought that small round bush for the other end of the dog bone mount? is it worth getting?
    Current
    Porsche Cayman S
    Gone but not forgotten
    Audi S3:Blueflame TBE; 3" blueflame downpipe; Forge 007p; jabbasport custom map; Badger 5 TIP v1, various bushes, N249 Bypass, Stack Boost Gauge, Junior GT Brembo brakes, tarox 2 part discs, DS2500's
  38. #157
    Apr 2007
    98
    Very hard to press out.....stiffens it up a lot though. You can get void fill bushes, just fill the void in original bush...easy to do , stiffens it up by 17-20% for about £15....superpro void fill bush.....good comments about that on the interweb.
    Audi S3 AMK
  39. #158
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by mrj0ey View Post
    Agreed. The problem is that there is a happy medium between too stiff and too soft.
    Too stiff will give you a LOT of vibration in the cabin which is very annoying and uncomfortable. Too soft allows excess engine movement.
    I'd say that just doing the main bush is sufficient.
    Homer Simpson
  40. #159
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    got mine done. cars shakes n vibrated from dashboard but not that bad! feels so much better! out my foot down n response is instant gears feel a bit better going in too defo worth doing.
  41. #160
    Sep 2006
    Sunny Suffolk
    554
    Does anyone know what torque the bolt that clamps the bushes together should be? i.e. not the 2 x 13mm bolts and neither of the "long" or "short" 16mm bolts.
    Hope that makes sense.
    EDIT: Torque the compression nut to 20 Nm (15ft-lbs) + 1/4 turn
Tags for this Thread
