Badger5Monster Motorsport
Results 1 to 11 of 11
    May 2010
    BERSHIRE
    41
    RNS-D Faulty Rotary push button on the right turns but does not OK (push in)
    Hi All
    Need some help, my RNS-D has Faulty Rotary push button on the right turns but does not OK (push in)
    is there somewhere I can get just the new button and replace myself or get fixed that will not cost me the earth
    will a button from a normal concert radio be the same?
    thanks
    Manj
    WANTED : BLACK LEATHER REAR HEAD REST FOR S3
    May 2010
    BERSHIRE
    41
    whats happened is the battery went dead, and after changing,
    i cannot put in the security code
    is there another way to ok the code??
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    ...is there another way to ok the code?? ...dont think so, you need to twist it to highlight the number and press it in to OK/select the number
    was the button working before the batery went flat?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    May 2010
    BERSHIRE
    41
    think it was cant be sure
    can it be set through vagcom??
    May 2010
    BERSHIRE
    41
    BUMP ANYONE??
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    sorry, i dont know how to help
    Alex S3 AMK
    May 2010
    BERSHIRE
    41
    bumping to top
    May 2010
    BERSHIRE
    41
    help.....
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Have you phoned your local Audi dealer? Perhaps they can confirm whether there is another method to input the security code...?
    Aug 2011
    Any response to this? as i have the same problem ....
    27,097
    If the buttons goosed, then think you're out of luck, you would need to desolder the dial of the pcb, strip it down & see if can repair, I know I have done a few before, its a a real pita job, but possible I reckon.
    I dont know anyother way to input secure code, than via front panel.
