Badger5Volks Autos
Results 1 to 9 of 9
    Reesy's Avatar
    East Sussex
    3,604
    Yet Another Fault Code Thread..
    Hi, the EML came on about 3 weeks ago on my late 2000 1.8T, and the faults were:
    1. 16825 - Tank Venting Issue
    2.17544 - Fuel Trim System too lean
    Got them reset to see if they were a one off, and the light stayed off for 2 weeks and has now come back on, the above codes were back, as was:
    17705: Pressure drop between Turbo and Throttle Valve
    Just wondering if these were common and what people had done to rectify the problems.
    Any help would be greatly appreciated
    Reesyboy
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    might help
    17705 - 17705/P1297/004759 - Ross-Tech Wiki
    16825 - 16825/P0441/001089 - Ross-Tech Wiki
    17544 - 17544/P1136/004406 - Ross-Tech Wiki
    never had any of these issues, but ross tech wiki always points you in the right direction
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Vacuum leak by the sounds... prob the PCV pipe under the inlet manifold...
    Start checking all the pipes for splits...
    <tuffty/>
    Reesy's Avatar
    East Sussex
    3,604
    Cheers for the links S3feates, was trying to remember the link for ages.
    Tufty - do you think this could cause all 3, or just the top 2? The link says the third could be DV related, but it isn't fluttering, which i thought was the tell tale sign it was on it's way out. Correct me if i'm wrong though...
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    no problem...hope you get it sorted soon! and let us know what it was in the end! good luck
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by reesyboy View Post
    I am pretty sure it will sort all the probs... the third issue can result from split pipes... the link assumes pipes are in a good state... sort the leak out first then see how you go...
    <tuffty/>
    Reesy's Avatar
    East Sussex
    3,604
    Thanks alot, will check a bit later on
    Does the PCV pipe part number differ for different engine codes, or is it a universal fit on all 1.8t's? Reason I ask is if i need a new one, I am unsure which engine code mine is
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Engine code is stamped on the clyinder head by the cam cover
    Reesy's Avatar
    East Sussex
    3,604
    Cheers dave, looks like I've got some fun times ahead trying to find the leak...
