Chris NottVolks Autos
Results 1 to 9 of 9
    darko's Avatar
    Dec 2004
    london, uk
    272
    AH Fabrications FMIC - Installation Questions
    questions for anyone that's fitted one before..
    Did you remove the metal pipe that runs behind the radiator and connects the 2 original inter coolers ?
    the lower part of my bumper really doesn't want to go back on, its predictably catching on the fog lights - just wanted to check it is actually possible to retain the fog lights ?
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    no in a word! You may need to trim the 2 45 degree silicone hoses
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    darko's Avatar
    Dec 2004
    london, uk
    272
    Ok, forge instructions leave it in place. I would rather remove it but it doesn't look straightforward.
    Thanks, I'll trim those elbows and try again
    S3 AMK - Revo - Bilstein B8 Dampers - H&R Springs - AH FMIC - And currently in pieces...
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    It actually holds the powersteering pipe on too, so unless you fab something it will have to stop on
    darko's Avatar
    Dec 2004
    london, uk
    272
    Ah right, it dud look like it was attached to other things
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    AH Fabs FMIC is designed to fit with the fogs in place.. I know as I designed it that way... if the pipes are fouling the bumper at the bottom then I would suggest spacing the brackets down from the bumper bar a bit as it was designed this way to allow adjustment to get the hoses tight under the fog light brackets...
    The bumper doesn't go all the way back to the original 2 holes underneath but everything should line up fine... I notched in where the original holes were to fit the captive nut a little further forward so I could fix mine in properly
    You don't have to remove the pipe that spans the front of the car and as said it is also a fixing point for the power steering pipework... I removed mine however and made a new bracket up for the PS pipes...
    <tuffty/>
    darko's Avatar
    Dec 2004
    london, uk
    272
    Perfect - thanks for that !
    Ill take out the grills by the fog lights so I can see what height the cooler needs to be at
    I might also remove that metal connecting pipe too then, dont want to leave it if its fairly easy to make a bracket for the power steering pipework
    darko's Avatar
    Dec 2004
    london, uk
    272
    Had another go today and I can see now how I need to get the pipes running under the fog lights, makes a lot more sense
    the old connecting pipe looks quite structural though, its connected with 6 bolts into the chassis legs !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    its not structural... very light steel and the A3's are the same chassis and don't have one... on the LCR's that are also the same setup as the S3 they have an alloy one...
    <tuffty/>
