JMB RetrofitsEM Tuning
Results 1 to 21 of 21
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Bottom end break down
    Nice casual drive to work and bang goes the bottom end! Rattles like mad when even on tick over and obviously worse whilst driving!
    Anyone had or know of this on and a3/s3 and can give me an expected cost I'll get to have it fixed?
    Just my luck!
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    If it still runs and rattles it sounds like the oil pump has gone causing the big ends to go.
    Not cheap if your getting someone else to do the work for you
    You could do what welly did and get a good second hand engine and fit that yourself or you could do what i did and rebuild it with performance parts yourself, but not that cheap
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Essflee's Avatar
    Mar 2008
    2,007
    Sorry to hear mate, haven't heard of a bottom end going.
    Was your car mapped ?
    revo'd
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    They go all the time, usually because of low oil pressure, caused by crappy maintenance and the dreaded sludge.
    At the very least its going to need a crankshaft, and a set of rods, then a full bearing set, new rings and a new oil pump
    TD5 Land Rover Defender build
    Jun 2009
    Leeds
    3,472
    Same thing happened to mine.
    Only had the car 8 months, oil light flickers on and off, took the sump off and found the drainer blocked and metal from the bearings in the sump, The engine was removed and found that the crank and rods were damaged also small scores in the bore.
    Thats by i built the stroker motor, the TDI crank was cheap and mint and then got the rest from I.E
    FOR SALE
    G60DAN's Avatar
    Cornwall
    321
    Sorry to hear that's sounds like what happened 2 me last friday but don't know if it top or bottom end.
    Jan 2011
    North West
    Sorry hear your bad news, secound hand motors dont seem to be cheap for these car so i would say a rebuild would be the better option with uprated parts. But it does all depend on budgets ect.
    Mike
    Pat
    Dec 2006
    512
    Dont know if you need but i have a crank, rods pistons etc etc.. all it great working order..
    2002 S3, Project 400, New Build In Progress, I.E 2.0 stoker kit, Big Port AGU Head, Ferrea Valves retainers, springs etc, GT30 compact, Pagparts Manifold, AH Front Mount Version 2, Genesis 550cc Injectors, 044 Fuel pump in I.E Surge Tank, Revo Stage 3 Software, Porsche Brakes, work in progress
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    cars been put into air cooled engineering, a vw/audi specialst near me in oxford. rang me this morning.
    Its coming from top end/gearbox ares apparently. So looks like dual mass/release bearing issue!
    Only had new clutch assembly fitted 20000 miles ago, surely that shouldnt be worn out totaly already? i dont ride the clutch often, maybe in traffic!
    car is remapped yeah, only stage 1 though?
    I serviced it about 4k miles ago, all filters and oil, apart from haldex. then a health check so im quessing oil level was ok.
    Im hoping its the clutch, although i had no pedal vibrations, or excess travel!
    Aug 2010
    bradford
    1,252
    soz to here about it mate.
    my car ratels when ticking over and it makes a nocking noise too
    how do u no when oil pump is ready to go or water pump tar
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Just got the most unwanted phone call from air cooled engineering! turns out.....its my Gearbox, float, flywheel....so clutch and release bearing too!
    Nice way to spend 2500?!
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by S3featesV9 View Post
    what happened before it went mate sid afects
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    ive had a ticking noise for ages, coming from airbox area above gearbox.
    driving along dual carriage way and you get a noise like something is wacking the underside of your car. then whichever gear your in....booom goes the cog. so in my case i had no 4th.
    Aug 2010
    bradford
    1,252
    if hop all goes well for ya mate
    mine just makes a nocking noise when ticking over for gear box area and it judders
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    Quote Originally Posted by s3gazz View Post
    Mine does that too but my techy checked it out and said thats the noise a triple plated paddle clutch and solid mass flywheel makes....
    it's been making that noise for nearly 2 years never got better or worse.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    mines never got any worse or better either, until last night. it was a really suddon, no actual give away signs that the gearbox was going...just the everyday rattle!
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by S3 Baby View Post
    so thats ment to do that then on my car i guess
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    yeah seems to be normal. ill soon tell when i pick it up after having all new parts fitted. it it doesnt make the noise then no. but ill be sure to post on here and let everyone no what the outcome is.
    Im hoping it sorts all ticking, knocking noises in all fairness.
    According to the specialist garage, first sign of gearbox/float failure is clutch pedal judder/vibration whilst sat in neutral and going though the gears, like in traffic. or if really bad, you can tell during normal driving conditions.
    Aug 2010
    bradford
    1,252
    thanks mate
    theres nothing wrong with my clutch abit stiff thats it like no juder or vibration in it
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    as i had mentioned id let you know if i still get the 'normal' noise coming from the gearbox after having the new one fitted....i now have no, not any sort of noise, juddering, ticking noise. So it being the noise a dual mass flywheel makes is incorrect!
    near gearbox, flywheel and clutch has made a big difference, probably nothing to do with it, but now seeing 30.2 mpg compared to the 26.6. hasnt even been reset. weird!
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    I feel for you. I thought I was unlucky with a replacement clutch slave cylinder dying after just 14k, I'm now relieved it was not the gearbox!
    Where are you in Oxford by the way? I live in Bicester, but work in Oxford city centre. Hoggy is also in Oxford.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
