AH FabricationsEM Tuning
Results 1 to 9 of 9
    Sep 2010
    Teesside
    31
    Help lost power then the esp light came on, S3
    Hi guys hoping someone might be able to help, whilst driving down the A1 tonight I had just been giving it abit and then returned back to sensible cruising speed and a couple of minutes later lost power, car is spluttering badly everytime I hit the throttle and then the esp warning light came on and is still on. Pulled into the hard shoulder but car didn't cut out and I sussed as long as I just feathered the throttle it would run smooth so I got of the motorway and pulled into a petrol station for a look but couldnt see anything obvious so I limped home a couple of times when I throttled to much it went into proper limp mode with epc warning but stop and start and this would clear.
    Any ideas
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    I have a similar problem, not sure if yours has the same symptoms mine did but i couldnt hear the turbo, it was like the 1.8 without the turbo, very little power...
    It turned out to be the cam case breather system(think the PCV - hockey puck - valve) was blocked with corroded rubber from the pipes.
    Worth checking rubber pipes for corrosion or blocking, as soon as i changed mine it was fine!
    Sep 2010
    Teesside
    31
    I'm off to have a look now so hopefully something simple like that
    Aug 2010
    Dumfries, Tartan-land
    203
    Disconnect the battery for half an hour and see how it is after that.
    I suspect either MAF or a coil.
    1998 Audi A3 1.8T Sport (AGU) - Remap, Apexi CAI, Scorpion CAT back, 3" downpipe/Decat, Coilovers, 18" RS4's
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Just resolved an identical issue with a friend's S3. Turned out to be the throttle body failing. Also when scanned, VAG COM gave an 'Internal Control Module Malfunction' error for the throttle position sensor (inside the TB).
    May be the same issue.
    EPC light is the giveaway here - electronic pedal control.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    www.badger5.co.uk
    May 2004
    nr Glos
    6,947
    hmm.. could be several things..
    blown a pipe off, maf expired, coilpack expired (misfire)
    etc etc
    needs codes read
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sep 2010
    Teesside
    31
    Had blown the boost pipe off where it goes onto the alloy pipe ontop of the engine, the end of the pipe is a bit suspect as some of the outer edge of it has come off and clip isn't great, I put it back on and went fro a run round the block and it looks like it's going to come off again so I've been to get a heavy duty jubilee clip in the hope that will secure it till I get another pipe.
    Don't know what the crack was with the esp light though but after the run round the block it cleared so hopefully back in business.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Glad your sorted mate, try and get any oil residues off the pipe and hose where they meet, then put back on with a decent clip...
    Sep 2010
    Teesside
    31
    Yeh I did, gave them a good clean with contact cleaner then refitted with new clip, have been for 10 mile no holds barred run and the pipe hasn't moved.
