Badger5Chris Nott
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Uneven wear on new front pads and discs
    Put some genuine Audi ones on the front with some BOSCH pads today.... Cleaned up the old slider pins, re-greased them, assembled and everything was looking good. Started to bed them in which was no problem but found that the protective coating wasn't wearing evenly on the NSF disc... The inner most 20% wasn't wearing away when compared with the OSF disc... (the pad didn't seem to be making complete contact with the disc else it would be removing the coating).
    So something's worn... Any ideas what? I've read about the solid bushings for the sliders but I dont want to waste money finding out the solution as money's tight right now
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    stacey bear's Avatar
    ST8C3Y
    Apr 2010
    Cambridgeshire
    187
    what protective cover are you in about?
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,108
    please tell me you cleaned the grease off the discs before fitting them
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Yeah, I done about a hundred discs and pad installs now There was no grease on them at all
    Lloyd149's Avatar
    Dec 2009
    York
    102
    Are pads seated right in caliper?
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Yup, they were. Solved by putting new OEM slider bushings in from Big Redd
