EM TuningSky Insurance
Results 1 to 11 of 11
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Drivers door wont open from the outide?? Pics included.
    So a couple of weeks ago my drivers door randomly just stopped opening from the outside. Opend from the inside fine but it's becoming a right pain in the arse now.
    So i got home from work early today and set about removing the door card to see if i could see any obvious problems.
    I got the door card off and this is what im faced with...
    The bit i really need to look at is covered by massive black metal panel rendering it almost impossible to see what's going on let alone try and fix it.
    Here's a better pic...
    As you can see it's pretty impossible to see whats going wrong but it looks to me that there are about 4 bolts which look to secure the matt black window frame to the door. I never realised this would be seperate from the door but it seems to look this way... Can anyone confirm this? If this is the case, would it mean by removing these 4 bolts i could almost remove the top 'frame' of the door with the window and mechanisms all in one? Thus allowing access to behind the outer door handle?
    Here's a pic of the bolt.. if anyone ca shed any light on this that would be great!!
    G60DAN's Avatar
    Cornwall
    321
    Yes that's it in a nut shell mark it all up so you put it back in the same place.
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Have you done it before then Dan?
    Other that the 4 boltd that i can see, is there anything else you need to do to move the frame from the door?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    on the a4 b7 b6 theres 5 bolts dont know on the a3
    but same kinda thing all the frame wondow motor etc come out then you can get to the lock
    as above mark up to get a good refit
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Ok thats cool, looks like a pretty straigh forward job (fingers crossed lol)
    Does anyone have any knowledge on how the lock/handle mechanism works?
    As its obvious that the inside handle is cable operated but i can't seem to understand what could possibly be at fault to stop the exterior handle working?
    Is it solely mechanicle? i.e no electrical componets??
    19scotty81's Avatar
    Push down and across !!!!!!!!!
    Dec 2010
    Newcastle Upon Tyne
    107
    The handle works off a rod which pushes down into the mechanism, there'll be some wiring to disconnect on the frame before you lift it out but it's pretty straightforward, there should be some wedges around 2 of the bolts that you need to make sure go back in the right place as it can alter the way your door closes so make sure you mark the positions of them, although seeing that your cars yellow and the bolts blue it looks like there's been a bit of previous shenanigans so they might already be missing
    2004 A4 Avant
    Akoya Silver | 2 Graco Car Seats | Buggy In Boot |
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Ok thanks.
    The bolts not blue mate it's metal with a yellow marker but i believe specsavers do free eye tests :P
    Thanks for your help dudes.
    G60DAN's Avatar
    Cornwall
    321
    Yes it's not hard me and a mate done it 1/2 hour to 45 mins
    19scotty81's Avatar
    Dec 2010
    Newcastle Upon Tyne
    107
    Quote Originally Posted by SamiG View Post
    Ok thanks.
    Ha, thanks just got back from Specsavers noticed Currys have got an offer on for decent cameras, maybe's worth a look,
    2004 A4 Avant
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Oh you don't like my photography..... :P
    19scotty81's Avatar
    Dec 2010
    Newcastle Upon Tyne
    107
    Actually laughed out loud when i saw this, mint !!!
    2004 A4 Avant
