Volks AutosAH Fabrications
Results 1 to 7 of 7
    From Show... to GO
    Nov 2010
    Stafford
    436
    Is it ok to remove the Charcoal Canister?
    Im trying to tidy up my engine bay as much as I can at the moment,
    so far I've removed the N249 hoses, and am in the process of replacing most rubber hoses with silicone.
    so wanted to know, is it ok just to get rid of the charcoal cannister?
    my mates got a 1.8T A3, and he got rid of his, so i don't see why i cant,
    Is there any positives or negatives to doing this?? other than just removing some crap from the bay?
    270bhp 13.6 1/4 mile
    Dec 2010
    Asherville
    24
    Hey coyle i removed mine when fitting the oil catch can and now the pcv breather system is alot cleaner, no negatives
    Silver 2001 Audi S3 quattro.
    GIAC, Samco TIP, catless mandrel bent 2.5'' 2 box exhaust, Aquamist WMI, SPEC stage 1 clutch, N249 bypass, Forge Spltr DV, Oil catch can, colder Bosch super 4 plugs. Has audio and cosmetics too
    From Show... to GO
    Nov 2010
    Stafford
    436
    sounds good to me, i'll get rid of it then
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by coyle View Post
    Leave the solenoid electronically connected to avoid fault codes .
    Make sure you vent the pipe properly as well to avoid fuel vapour in the engine bay - can cause obvious issues such as large explosions and the like.
    Finally, cap off the metal pipe which runs across the bulkhead - it goes to both the TIP and the TB. This left open will cause you a large vac/boost leak.
    Homer Simpson
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Hahahaha
    darko's Avatar
    Dec 2004
    london, uk
    272
    Is there a guide anywhere to doing this ?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    There sort of is on my hybrid build thread. I'm on my phone so can't put a link.
    Homer Simpson
