EM TuningAH Fabrications
    Jan 2011
    77
    fault code 17536...
    keep getting the above fault code (every few days it comes back on after clearing it )and when i looked it up it comes up as:-
    Possible Causes
    • Mass Air Flow (MAF) Sensor faulty
    • Oxygen Sensor Control faulty
      • Oxygen Sensor(s) faulty
    • Fuel Injector(s) faulty
    Possible Solutions
    • Check Mass Air Flow (MAF) Sensor
    • Check Oxygen Sensor Control
      • Check Oxygen Sensor(s)
    • Check Fuel Injector(s)
    my question is will this be a costly fix? . Its a 1.8 sport i have
    thanks
    Scott
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Well with the MAF, you can just disconnect it and drive to see if it feels any different, if it feels the same it is ok.
    The oxygen sensor fault, im not sure, but i know the S3 has 2 of them, its a case of finding which one is faulty if at all and go from there....
    Best bet is to look on Euro Car Parts for prices on part or call your local TPS
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,543
    That fault code comes up as:
    17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
    (Ref: 17536/P1128/004392 - Ross-Tech Wiki)
    this suggests you have a vacuum leak... probably a split PCV or other pipe under the inlet manifold..
    <tuffty/>
    Jan 2011
    77
    thanks for the replys guys, how many hoses are there to check?
    Nilz's Avatar
    Apr 2006
    10,087
    There are quite a few pipes there mate, so its a case of trial and error, if you can get a smoke test or a compression test done on the car, that will identify where the leak(s) are straightaway.
    Ideally you are looking near the Inlet manifold, as the ones around here have a tendency to perish, due to the holt/cold treatment they get under the bonnet.
    Jan 2011
    77
    thanks, will get it checked out
