Monster MotorsportBadger5
Like Tree1Likes
  • 1 Post By Welly
Thread: Coolent warning light and sensor, easy to replace sensor
    MingeBlue's Avatar
    Feb 2008
    112
    My Coolent warning light has started randomly comming on when I start from cold, the coolent level is fine, also noticed its struggling a bit to start from cold.
    I did a bit of a google-ing and its points to the Coolent sensor being faulty which is a common fault, I noticed some people mentioned replacing the sensor and header tank, do you really need to replace both ? Is it as easy or easier to replace the coolent sensor compared to the temp sender ? I ask because I did the temp sender a year ago and I managed that ok
    2002 A3 1.8T
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yep, new header tank as far as I know - it's moulded in.
    A couple of bolts and two pipes - not hard.
    A3whitey likes this.
    Homer Simpson
