JMB RetrofitsChris Nott
Results 1 to 16 of 16
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Hey audi fans can you help me with stalling a3 1.8t
    Hi all
    Can someone give me a f&@kin cryptic clue to why my audi a3 1.8t with the engine code aum, keeps stalling when i come to a stop from average speed? It normaly feels sluggish from start up and has the revs at about 700 at idle when its going to play up. I had the same problem with my previous car that was a leon cupra 1.8t, but i never solved the proble due to the car being wrote off. Any and all ideas/help is welcome as i bet its something reli stupid. Iv checked for boost leaks and ther are none... Even my mechanic is abit stumpd as he suggests it could be a few things but not sure what without changin all of them to find out , but as work is tight i cant afford to do that.
    Thanks for any help.
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    have you had it scanned for fault codes?
    Aug 2010
    652
    throttle body reallignment? clean trottle body maybe first then reallign. something i need to do to stop my odd idle. can go miss alligned after disconnecting the battery.
    Nov 2010
    1,673
    No mate iv not had it checked but will probly just to be safe. But my previous car did the same and had no engine codes.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Vac leak. Next to guaranteed.
    Check all the boost hoses, the diverter valve piping, and the vaccum hoses around and under the inlet manifold.
    If it's stalling, it should be a hefty split...
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    Potentially a vacuum leak... check pipes under the inlet manifold especially the PCV ones as they are prone to splitting
    <tuffty/>
    Nov 2010
    1,673
    Hey all iv got the garage to have a check and thers no fault codes stored. All hoses are sound as iv got a cold side relocation kit so evrything is as good as new. But i have noticed im usually hovering just under the first quater of a tank when the car plays up. Iv filled it to the brim and put some injector cleaner in, and touch wood it has not stalled. Could it be crap in my tank or a pump playin up or somthing? Thaks for all the suggestions lads.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by camscockle20vT View Post
    Could be a dicky pump, lots of fuel in the tank will aid with fuel pressure as the weight of the fuel helps. Change the fuel filter first - most likely never been done.
    Homer Simpson
    Nov 2010
    1,673
    Ok dude ill give that a go. Gutted about the reliability of my latest audi as all my other audis have been golden. Im trying to get it running as good as possible before i get it remapped. Dodgy services from past owners has made it very costley to put right. Only paid 1800 on a 51 plate so i suppose you get what you pay for.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I changed my fuel filter and it was a lot better starting in the mornings, and the fuel was black in the filter
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Nasty. Why they aren't on the Audi service regime I don't understand... That and the cam belt tensioner damper. Idiots.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Fuel filters here:
    Bosch Audi | Euro Car Parts UK
    Homer Simpson
    Nov 2010
    1,673
    thanks for link mate, my mechanic has changed the filter and he told me it was brown, so its a good chance its the filter. its got a full tank of fuel now and hasent stalled since. lets hope it stays that way. cheers for all your suggestions.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    No probs. Glad it's fixed....
    Homer Simpson
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    i might change my fuel filter for the sake of it. cant remember if it was done last service
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DaveA3 View Post
    For 9 or whatever, worth doing IMO.
    Homer Simpson
