Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Drivers door won't open on my S3 :( Please HELP
    Can anyone help??
    My drivers door has randomly stopped opening from the outside and i have no idea why
    Opens fine from the inside though.
    Only way i can get into my car is to hold the unlock button down so the windows drop and then stick my arm in and use the interior release handle.
    Anyone got any knowledge on what you need replacing/fixing??
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    when is icey outside or just in genral ?
    my drives will not open when the car is frozen. have to climb in through hte passanger side
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Aug 2010
    Dumfries, Tartan-land
    203
    Same here.
    1998 Audi A3 1.8T Sport (AGU) - Remap, Apexi CAI, Scorpion CAT back, 3" downpipe/Decat, Coilovers, 18" RS4's
    From Show... to GO
    Nov 2010
    Stafford
    436
    Take your door card off, and try and open it from the outside, and look at the inside of the handle to see whats happening,the hinge joint on the handle may be jammed,or one of the metal rods could have come off, that would explain why its still working from the inside handle
    beachbuggy's Avatar
    Surrey
    1,727
    There's a metal rod that runs from the handle to the latch, if that's come off,bent etc it will cause the door not to open. Only way to chk as coyle said is to take the door card off and have a look. Hopefully you should just find something unclipped.
    Aug 2010
    650
    ha ha. me too! damn ice
    From Show... to GO
    Nov 2010
    Stafford
    436
    Ice will make everything stiff,so pretty common, as its likely quite dry anyway so ice will stop it moving,
    It can only realy be one of two things, so if you have the door card off im sure you'll sort it easily
    Aug 2010
    203
    It works 90% of the time, but only when iced up will it not work.
    Similar problem really as when you shut the door and it just bounces back.
    Ice gets into the mechanism and it stops it working.
    Cup of hot water over ther latch does the trick for that problem, but not sure on what to do about not being able to open it from the outside.
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    292
    not sure if this is applicable to 8L a3/s3s but the mk4 golf had a similar issue whereby a little black tab used to get loose/pop out causing the outside door handle to stop working. you have to remove the plastic covering on the door handle (the squarish part) and re-insert it... or superglue it if it's broken :-D
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
    GeneralWest's Avatar
    Sep 2009
    Cambridgeshire
    168
    Mine did the same a couple of days ago. The drivers door wouldn't open from outside when it was icy that morning, so I climbed in from the passenger side and it opened with no effort at all from inside but it still wouldn't open from the outside. There were no sounds of ice cracking or anything when it opened. By the time I'd driven 15 miles it was fine and it's been ok since. I'll see what happens next time it's cold again.
    Now: 2001 S3 Nogaro Blue
    Then: 2000 S3 Black
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Thanks for the replies guys!
    Definitely not ice as it's like it all day everyday!
    Gonna take the doorcard off when I get a chance!
    Working 13 hours a day 7 days a week doesn't leve me with much time to fiddle at present
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    anyone got any advice/tips/how to's on how to remove the door card withour breaking anything lol.
    no idea where to start with interior stuff
