Badger5Chris Nott
Results 1 to 24 of 24
    Don's A3 TTu's Avatar
    Nov 2008
    Surrey
    316
    TQS on launch strange delay only happens sometimes!
    sometimes ill launch off the lights ill get about 10ft then the thottle will cut off (maybe traction control kicking in) for a split second and then kick back in
    i think its cos im running the standard haldex?
    answers on a post card!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Could be the traction control, have you got the switch to turn it off??
    Dont know if it will be haldex, as that provides more grip and just spreads it out doesnt it, dont think it will hold the car back.
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    if your giving it full beans then your car is 4wd i think, dont know what happens if the ECU automatically adjusts the throttle for you though, maybe if throttle drops low your back to 2WD?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    have you had it scanned for fault codes?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    Traction control most likely Don, since your car is running so many horses, I'd imagine it could break traction quite easily.
    Nov 2008
    Surrey
    316
    Quote Originally Posted by nilz18t View Post
    yeah i should try it with the traction control turned off but it doesnt happen that often so its hard to judge and i kinda need the traction control on with 300+ ponies under the bonnet! ill definatly have a go though cheers mate
    Nov 2008
    Surrey
    316
    Quote Originally Posted by Dane View Post
    yeah no faults
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    If you are launching with ESP on then that will be the issue here... mines like hitting a brick wall so I always turn it off...
    Launching with a std haldex controller (and ESP off) sometimes feels like you have been shunted in the back as the haldex will be off initially and only kicks in after wheelspin from the fronts is detected then comes in with a jolt... the performance haldex (so I understand) works from throttle position so 'should' engage the haldex pretty much instantly on a launch as you are generally using high rpm to launch...
    <tuffty/>
    Nov 2008
    Surrey
    316
    Quote Originally Posted by jojo View Post
    yeah probably, might have to wait till it warms up before trying to drive it all the time with esp turned off
    Dane's Avatar
    Cheltenham
    4,003
    Quote Originally Posted by tufftybloke View Post
    The performance haldex (so I understand) works from throttle position so 'should' engage the haldex pretty much instantly on a launch as you are generally using high rpm to launch...
    <tuffty/>
    Hmm if thats the case thats hella cool and I want one lol!
    Nov 2008
    Surrey
    316
    <tuffty/>
    yeah sounds the same as me then cheers mate, funny thing is when i was at santa pod i got my fastest time with the esp on
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    You need proper quattro :P
    TD5 Land Rover Defender build
    Nov 2008
    Surrey
    316
    Yeah well you need a proper TURBO :P
    "Stick a V8 in it!"
    15,324
    hehe yep i sure do!
    28RS will find its way onto there at some point, just now i need to focus on getting the sheds engine back into one piece and getting the car running again, and replacing the 10 year old suspension bushes, arms and other associated parts on both cars!
    Once all the running gear is un-soggy, then i can look at giving it more thrust!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    ....Once all the running gear is un-soggy, then i can look at giving it more thrust!
    ...hehehe... you said thrust!...
    <tuffty/>
    Dane's Avatar
    Cheltenham
    4,003
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    <tuffty/>
    You have to drive one to feel the difference Paul, you can feel the Haldex is already engaged before the power is transmitted to the wheels, most noticeable when changing gears at max revs, the car doesn't squat between gearchanges!
    Nov 2008
    Surrey
    316
    oh dont your getting me all excited i want one badly but i need a new clutch first
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    Quote Originally Posted by Don's A3 TTu View Post
    It's an expensive bit of kit for what it does though.
    Don't know if you think the S3 in the vid below is launching quick?
    Nov 2008
    Surrey
    316
    im at work cant view videos ill av a look when i get home! if you can check out my launch at pod when i done the 12.9 run against the rx7 its on you tube just search ( A3 TTU ) youll find it
    Nov 2008
    Surrey
    316
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    298
    hiya mate, i had a similar issue... unplugged the n75 and it worked just like i expected it to. basically for me, the n75 was knackered
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Holy crap, is that because of the Haldex controller?!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    Quote Originally Posted by JD09 View Post
    Apparently so, but I've yet to try it in my S3! I've done the max revs gearchange, but I care about the transmission too much to do full throttle in 1st gear launch.
