Chris NottJMB Retrofits
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    Rear wheel speed sensor
    VAGCOM says there's a fault on the lefthand rear wheel speed sensor.... is lefthand as i'm sat in the car ?? ie passenger side ?? bit of a lame question i know but i'm sure i read they are handed so i dont wanna get the wrong one also is possible to remove the sensor without removing the wheel hub ??
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    Left hand side is passenger side for a UK car.
    beachbuggy's Avatar
    Surrey
    1,745
    Yes sensor can be removed without removing the hub. Jack the car up, remove the wheel, undo the screw with a 5mm allen key. Spend the next hour trying to get the old sensor out! and then refit the new one.
    If the sensor wont come out easily, which i'd be very suprised if it did, the only way I have found to get them out is to remove the screw, then use a chisel to break the sensor in half. Pull out the all the wiring from inside the sensor which is a lot of thin copper wiring, then using a thin screw driver gently tap the head of the screw driver inbetween the plastic sensor casing and the hub. It should at some stage crack the casing and then it will easily to pull the rest. Once done, clean the inside of the hub hole and refit the new sensor. It's a little bit rough and ready way of doing it but it works and as long as you are careful wont damage
    Mar 2008
    Oldham, Manchester
    1,110
    thanks beach...... sounds like they are as bad as the front ones then as regards getting out.... dosnt matter what i do to it though if i'm fitting a new one
