can i use these resistors for the evap canistor (air con) and air bag wiring to remove the fault codes?Are you asking the same question as you did here?
http://www.audi-sport.net/vb/a3-s3-...41-fitting-agu-lump-into-my-s3-need-help.html
If so then as Tuffty says it's actually the SAI, take it you mean this
Like I said on your other post. I've just done this with no problems.
Also remove the SAI pump , and just used a 10w 470ohm restistor from Maplins 69p in the contector so the ECU doesn't throw up a fault code.
because ive stripped them out so i know they dont work coz theyre not there!!!WTF?? Why would you do this??
N75???Ohhhhhhhhhhh. Lol. I wouldn't have thought so mate to be fair, N75 is what I generally use.
N75???
lol, I have replaced several sensors with old duff N75 valves... Thats a pretty universal plug on the 1.8T engine.
