Chris NottEM Tuning
Results 1 to 8 of 8
    Dec 2010
    22
    Running veggie oil on ma 2001 tdi non pd
    Hi
    As above, just wandering if its safe. To run veggie oil without any modifications to the fuel system, looking to only run a 3 part diesel to 2 part veggie just to bring ma bill down.
    Any info appreciated
    Thanks in advance
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Quote Originally Posted by Mudz View Post
    Hi
    Thanks in advance
    Vegetable oil and TDI engines | The Smart Drive
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    3,991
    Aren't there some fairly serious consequences if you get caught doing this? Plus your car will smell like a deep fat fryer
    Dec 2010
    22
    Thanks for the link but im not wanting to run straight veg oil but a mixture of mostly diesel
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    If its a PD engine, then forget it.
    If its a VE Rotary Pump then you may get away with it, subject to sufficient fuel heating etc.
    Your allowed to legally use 2000L a year without paying tax on it from what i've heard, although that may only apply to biodiesel you've made yourself rather than SVO you've baught from Tesco.
    The other point is that is it really worth the risk for the cost savings?
    If you've got a steady supply of used oil for free, and have build yourself a biodiesel processor then great, run it neat and save some money.
    But mixing dino (at say 1.30 a litre) with veg oil (at say 1 a litre) at a 50:50 ratio means your paying 1.15 a litre to fill the car, a saving of 7.50 a tank. Ok its something, but is it really worth the hassle of having to lug vats of veg oil around, plus the money you have to invest in fuel heaters, especially when combined with the risk that the fuel will damage the engine.
    TD5 Land Rover Defender build
    Dec 2010
    22
    Well ill be using used veg oil all filtered and de watered at a cost of 0.50 a litre with a 3 part diesel and 2 part veg oil ma fuel bill will be down to about a 1 a litre
    "Stick a V8 in it!"
    14,909
    So its not SVO then its waste oil.
    No way would i be putting waste oil in my engine, it may be filtered, but you've no idea what crap is in the oil itself, it will be full of fatty acids and suchlike which occur as natrual byproducts of cooking.
    Only thing i'd be doing with that is converting it to proper biodiesel.
    Dec 2010
    22
    Your right i could have worded it better. If it was converted to bio diesel it would go through the same filtering process so would still have all the fatty acids init.
    I had been using the same stuff in ma 306 d turbo for 40000 miles with no problems, i was just asking on here if anyone else had done something similar
