AH FabricationsSky Insurance
Results 1 to 11 of 11
Thread: Heated Mirrors
    Stockton-on-Tees
    23
    Heated Mirrors
    Does anybody know how the heated mirrors are wired? Mine dont work so i checked the circuit through them and they are open circuit. so it looks like i need new ones. When i checked the supply to the mirrors i found that i have a live feed as soon as the ignition is switched on, i thought they came on with the rear screen heater!!! Do i have a fault with a relay? if so where is it and could it be that a thermostat is overriding the rear screen switch.( it is cold today) Thanks in anticipation Martyn.
    May 2004
    Billericay, UK
    278
    Re: Heated Mirrors
    From previous posts they are temprature based - once it gets cold they will automatically switch on. The glass heaters have a tendency to burn out, I believe I have this problem too.
    Replacing the glass is the only way to fix the problem that I am aware of.
    Greg
    Stockton-on-Tees
    23
    Re: Heated Mirrors
    been to stealers and paid 55 the pair, fitted and heated up straight away. but found to be cold again when i got home. switched ignition off and then on again and they worked again, have`t tried rear heater switch yet. Do they work on a timer? i thought they were on all the time thats why they burn out.
    Oct 2004
    34
    Re: Heated Mirrors
    think ive got same prob also where did you get glass from?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Re: Heated Mirrors
    [ QUOTE ]
    Bigshout said:
    I thought onlt the drivers side heated up. Is this true or should be both heat up!
    [/ QUOTE ]
    Both should heat up [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Re: Heated Mirrors
    [ QUOTE ]
    [/ QUOTE ]
    Yup, they are on timer, to prevent them from burning out - supposedly [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Re: Heated Mirrors
    [ QUOTE ]
    [/ QUOTE ]
    I got mine from KMS based in Birmingham, as I drive past there quite often, and just popped in. Try Euro Car Parts or German & Swedish for mailed orders, or vagparts.com for OE parts.
    Stockton-on-Tees
    23
    Re: Heated Mirrors
    got them from teesside audi, 10 cheaper if you dont want the blind spot mirror. they keep them in stock which would suggest they are a regular spare.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Heated Mirrors
    The early ones came on ALL the time and so were prone to burning out, replacement being the only repair option. The later ones and the ones you would now buy have thermistors in them to only come on at temps less that 5c. Neither of mine work LOL
    recomdos's Avatar
    Feb 2004
    North East
    988
    Re: Heated Mirrors
    [ QUOTE ]
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    never checked mine....
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Re: Heated Mirrors
    [ QUOTE ]
    recomdos said:
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Rob, bet you've got so much crap on your wing mirrors, you can't see out of them anyways. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
