Monster MotorsportChris Nott
Results 1 to 16 of 16
    Aug 2010
    bradford
    1,252
    lambda sensor question
    hi i have a amk 225 s3 and need the lambda sensor for my down pipe is it the same as the one near cat or not and how many wires does it have tar
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    They are different to each other if i remember right the top one has 5 wires and the bottom 4 but it could be the other way round been a while since i did mine
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Speedy Steve View Post
    Deffo different.
    Had a quick look on euro car parts, but they don't stock a wideband pre cat sensor sadly.
    Homer Simpson
    Aug 2010
    bradford
    1,252
    Deffo different.
    iv been quoted 60 from gfs for down pipe one that seems ok to me other one i payed 40
    would it be that thats coursing bad fuel consumption loss of power and crap drive
    or is it the egt sensor tar lads doin head it now maf sensor fault as well god nose witch one it could be argggggggg
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Both egt and lambda contribute to bad fueling and loss of power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    I thought I answered this in one of your other threads,,,
    my esp light wont turn off
    <tuffty/>
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    soz i forgot about that thead mate tar
    to u does it sound like all of the problems egt or lambda or maf
    or could it be one of them tuffty witch one should i change first them mate tar
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    do me a favour and rescan your car for faults and post them up... lets start from there...
    <tuffty/>
    Aug 2010
    bradford
    1,252
    thanks tuffty ill post the onto her mate wont be long great help i o u lol
    Aug 2010
    bradford
    1,252
    <tuffty/>
    here we go mate
    01314 engine control module
    17833 evap purge valve (n80)
    16955 brake switch f
    16486 mass air flow sensor (g70)
    17523 oxygen lambda sensor heating b1 s1
    17861 exhaust gas temp sensor 1 (g235)
    17525 oxygen lambda sensor heating b1 s2
    some of the other faults have gone since i had my cat took off today so thats abit better
    cheers tuffty
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by s3gazz View Post
    here we go mate
    cheers tuffty
    Having a quick look at some of those codes seem to come up as 'short to ground' as a common description...
    Judging from your ECU 01314 error I am of a mind that the cause of a lot of these errors are due to the ECU picking up another problem
    01314 - Ross-Tech Wiki
    Also digging around I found this..
    VWVortex.com - got 8 codes 17880 17833 17525 17843 etc
    Has some similar codes to yours... all the posts seem to suggest fuel pump relay for some reason... thats a start point at least...
    Google is your actual friend btw ;P
    <tuffty/>
    Aug 2010
    bradford
    1,252
    <tuffty/>
    cheers mate great help where is the control module and how will i find fault i best off going to see a car electriction who nose what hes doing
    where is the o2 sensor mate i dont now non of these lol and how much are fuel pumps looks like ill buy one and fit it see what happens canot be that dear
    would u say im still needing lambda sensor or egt sensor and maf or fit fuel pump and go from there this helped alot mate tar
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    I think at this point my friend its worth taking it to a specialist...
    O2 sensors are lambdas... fuel pump relay should be under the dash drivers side IIRC but no idea what one...
    I would personally get the car checked over by a qualified auto electrician as all the faults you have appear to be the result of a larger problem... I suspect if the initial problem is fixed then most of the other faults should clear...
    <tuffty/>
    Aug 2010
    bradford
    1,252
    <tuffty/>
    thanks mate ill do that then and leave all those things for now ill change fuel pump see what crack is tar again tuffty
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Fuel pump? fuel pump relay you mean....
    <tuffty/>
    Aug 2010
    bradford
    1,252
    soz mate ye i was messing around under there fitting a brake switch last week could i ov nocked something tuffty
