Badger5Sky Insurance
Results 1 to 32 of 32
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    MAF readings are low....is this correct?
    I had a MAF error few weeks back which was cleared and has not returned since. Is a reading of 10.7g/s at 3k revs standstill correct? Or is my MAF on it's way out?
    Cheers,
    Chris
    2001 S3 - Ming Blue, Bose + AndyMac Stealth Sub + XCarlink iPod Interface with Bluetooth, Forge 007 (Yellow Spring), Green Cotton Panel Filter, Angel Tuning Remap, Milltek Cat-Back Resonated, Parking Sensors & Full Black Leather Nappa Recaros with Piano Black Trim.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    u need to go for a spirited drive. try to get max revs 6500ish in 3rd gear. ull get proper readings then. too hard to compare revving on ur drive like.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Theses are some of my readings from 4k to 6k full load. How do these look?
    RPM Inj. On Timing Mass Flow g/s
    4440 150.4 143.28
    4840 155.6 144.86
    5240 149.6 147.06
    5560 142.1 152.33
    5880 133.8 144.83
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by g10chy View Post
    4440 150.4 143.28
    4840 155.6 144.86
    5240 149.6 147.06
    5560 142.1 152.33
    5880 133.8 144.83
    You need to do the readings to redline to be honest mate. Up to 6K isn't really that helpful.
    Considering that though, the readings are low, even at 6K for a remapped car.
    3rd gear, 3K to redline will give a good reading of the airflow - then post them up.
    Homer Simpson
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    OK cheers Welly. I will try and borrow my mates cable overnight so I can get some proper runs logged and uploaded.
    Could it be that I simply have a sh!te remap? As my boost pressures seemed abit low also averaging between 17-20 psi with WOT!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Well, it's a bit hard to say. The values are low. You are making around 190 bhp at the best point of the values you posted.
    Could be a dying MAF, could be the map... But it would have to be an epicially bad map, as looking at what you posted before, it will struggle to make standard power.
    Homer Simpson
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Welly - Could I email you the full log which has group 115 and 002 for the quick test run i performed for you to cast your eye over a bit more? Quite worried i've not been reaching its potential for quite sometime now
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yep, no problem, I'll PM you my email address.
    Homer Simpson
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Cheers man. I have just sent you the log.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,379
    Those airflow figures sound really low to me. especially for a mapped S3!
    Even without going to the redline, here's a tiny extract from the one log I could find on my work PC.
    This is a ko3S turbo too, not a ko4.
    RPM Airflow (g/s)
    4120 150.07
    5080 173.75
    5840 186.39
    6560 187.15
    So that's just an A3, and at 5000rpm it's making almost 20g/s more than you're mapped S3! something big time wrong there.....
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK, looking at that log, the airflow does look to be down, but it's difficult to be sure because it never gets to redline, and all the bursts of acceleration are short.
    If you can, go out again and log block 002, 020 and 115. Timing pull (020) is a useful block to log because it gives you a better insight as to what is going on.
    Try, again if you can, to do a several full runs in 3rd (or 4th if you are brave enough) from 3K all the way to 7K. Nice log logs are easier to gets useful info from.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    RPM Airflow (g/s)
    4120 150.07
    5080 173.75
    5840 186.39
    6560 187.15
    Agreed, mapped S3s should be expecting 200 g/s or close to.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Again, here is a brief excerpt from one of my very old Stage 1 REVO logs:
    Code:
    	RPM	Inj. On Time	Mass Flow
    TIME
    STAMP	 /min	 ms	 g/s
    165.28	5600	19.27	194.69
    166.48	5840	18.86	199.25
    167.68	6080	18.04	198.92
    168.98	6320	16.81	194.42
    170.29	6520	16.4	189.42
    171.49	6680	15.99	191.64
    I have sent you the whole log for comparison.
    Homer Simpson
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Welly - Nice one for looking...I am borriowing my mates cable tonight so I will get some better runs logged. The roads were too busy this lunch to get any decent runs!!
    Will be in touch later.
    Cheers,
    Chris
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    As per my email back mate, with standard S3 210 log attached for your reference.
    Homer Simpson
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    I still want to know why I got 186 from a standard car.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    There was a hurricane that day that was blowing into your maf for a brief moment.
    Just a guess like
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    433
    Quote Originally Posted by JD09 View Post
    I got 181 from my standard S3, yours must be running that little bit better.
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Welly - I have just done a run in 3rd from 3k to redline....not looking good I have sent you the full log but the max MAF reading im getting is 159.5g/s!!!
    Im also getting a few Idle Stabilization figures which im guessing is not good also?
    Any ideas whats wrong?
    Cheers,
    Chris
    RIP S3dave
    May 2004
    nr Glos
    7,191
    tired maf... most likely
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Lots of timing pull on the logs as well though. Not horrendous, but seeing 6s.
    Homer Simpson
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    If the maf's tired wouldnt the fuelling be all over the shop though?
    Running lean will cause timing pull?
    TD5 Land Rover Defender build
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yep, it's got dodgy MAF written all over it....
    Homer Simpson
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    OK nice one guys!
    Will the below part be OK or should I get and OEM one direct from Audi?
    HTML Code:
    http://www.eurocarparts.com/ecp/c/Audi_S3_1.8_2001/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?434440150&1&a413bd08cf642550236330dbb8c7f97fc7dcaf12&AFME
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK nice one guys!
    HTML Code:
    That one should be OK, as long as it's a genuine Bosch unit it will be fine. Check that with them beforehand.
    EDIT: Is does distinctly say 'Bosch' on the listing, so should be fine...
    Homer Simpson
    JD09's Avatar
    Dec 2009
    3,080
    I'm going to log again tonight and see what mine is now getting.
  28. #27
    RIP S3dave
    May 2004
    nr Glos
    7,191
    it wont be helping the fuel trims... but if wideband car it will still be controlled by lambda
    www.badger5.biz
    bill@badger5.co.uk
  29. #28
    RIP S3dave
    May 2004
    nr Glos
    7,191
    yes.. seen it a lot
    www.badger5.biz
    bill@badger5.co.uk
  30. #29
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Getting my mate at Audi order me a new MAF....Discounted parts
    Will then do another log to see if the MAF readings have improved!!! Fingers crossed
  31. #30
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Good luck dude, hope it sorts it for you. Should unlock some power for you....
    Homer Simpson
  32. #31
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    Just fitted the new MAF and performed a new run feels alot better!!
    How do I get the results from Excel into the post without losing the formatting?
    Cheers,
    Chris
  33. #32
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Chris, as per my email reply, there is still a little extra timing pull than is ideal. 6s are generally considered to be the limit of safe with regard to timing pull.
    I would take your top hoses off to check for oil inside - excess oil in the charge system can often cause higher than average timing pull figures. If there is a lot of oil, clean out as best as you can and then re log. Then keep an eye on the amount of oil in the charge system.
    I notice that it is only under heavy load in high gear, so you may want to avoid doing this too much until resolved. Ideally the timing wants to be backed down a little bit. Who mapped it?
    MAF readings are much better - a massive improvement. I would imagine there is an improvement on the road as well?
    Nice work - glad that the MAF problem has gone.
    Homer Simpson
