AH FabricationsJMB Retrofits
Results 1 to 11 of 11
    gavcav's Avatar
    leeds
    27
    advice needed re:ABS / ESP intermittent warning lights
    advice please guys... from reading the forum i've found it's a regular problem.
    tonight my ABS and ESP amber caution lights illuminated and remained on. i got home, had a read of the manual and forum etc and without jacking up the car and removing the wheels, i went to check the car for obvious leaks, damaged wires. i couldn't find anything obvious.
    i started the car up and found the ESP light had gone off. i then went for a short drive and the ABS went off too.
    i thought everything was good again, then they re-appeared for some minutes, then went off again.
    11 days ago i had to replace the rear pads, so i'm wondering if i've disturbed a sensor or not?..if i had, i would have thought i'd seen problems before now?
    what do you think as a first step?.. clean sensors/sensor plugs?..vagcom? (which i don't have so it'll cost me 's)...or is it a sign of something more serious? (ABS module).
    i'm not sure what step to take next, so any help would be appreciated...thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    1st step is to get it on a scanner and read the codes
    even if there not on they will be stored
    i had this a few weeks ago and it was my battery going dead
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Im in leeds and can get it on the computer for you on saturdays if stuck, it can be many things and a scan will tell you...
    gavcav's Avatar
    leeds
    27
    thanks lads....s3dave, thanks mate, i may take you up on that..i've never used this vagcom thing, is it straight forward to do?
    gavcav's Avatar
    leeds
    27
    ok if i pm you s3dave?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by gavcav View Post
    yes just plug in, pm me if you want it scanned
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Likely to be an ABS sensor, especially as you have just done your rear brakes. Happened to me after doing my fronts last year. They are only ~15 a pop, so not an expensive fix...
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by alijames View Post
    Cheers,
    or the longitudinal sensor which is part of the ABS system : 150
    bargain
    Aug 2009
    174
    i got the same problem on my a3 can drive 4 miles with lights on then switch off and restart the car and they stay off for a while doing rear brakes today and discs also having a scan done will post any codes later today
    Feb 2008
    2,817
    This happened to me and was one Of my throttle sensors. Cost about 100 from midland VW to fix.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Aug 2009
    174
    done readout came back as front o/s abs sensor this problem started when i replaced front discs so have cleaned sensor and ring been for a spin and so far so good hope this helps if it comes back on will replace sensor unit cost around 15
