Chris NottMonster Motorsport
Results 1 to 11 of 11
Thread: thermostat ?
    hilly's Avatar
    Oct 2009
    wakefield west yorkshire
    181
    thermostat ?
    my s3 temp does not reach 90 or sometimes does then drops back to the mark below 90.i am right in thinking this is the thermostat? or could it be temp sensor?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Thermostat, mines doing the same after changing my temp sender.
    May 2006
    Lancs
    211
    Sounds like the most likely cause. It's a bit of a pig to fix because it's tricky to get to but anyone with basic spanner skills should be able to sort it.
    hilly's Avatar
    Oct 2009
    181
    cheers,will have to sort it soon it bugs me lol!
    handy andy's Avatar
    Jul 2010
    75
    Just done both..CTS and the thermostat.As it was doing the same as yours.
    I thought i would try the CTS first as it was the eisier of the two to replace.After a couple of days driving the car after replacing the result was...The needle was a little more stable,as it was going upto about 80 then moving up and down a bit!
    So earlier this week i replaced the thermostat and Bobs your uncle.Sits at bang on 90 and gets there in about 5 mins,even in these temperatures!And my MPG's are much better...Thank God!
    My advice would be to follow my route as the CTS was 31 and if that cures it you'll save yourself another 25 and the hastle of fitting the thermostat.
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    My temp gauage hardly moves at all, got the fault on vagcom so chaged the temp sender but no luck. Could it be the thermostat?
    BTW whats the CTS?
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    May 2006
    Lancs
    211
    Coolant Temp Sensor, have a habit of going chips without any really obvious side effects but can cause bad MPG. Since I changed my thermostat it gets up to temp quickly and now always sits at 90, very handy at this time of year as cold running really increases fuel consumption.
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    ah ok, thanks. My CTS should be fine as it was changed last week, hopefully should be thermostat then...
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    292
    andy mate, where on earth did you buy a temp sender for 31?? i got mine for 12: even the original thermostat from tps is 15.
    i had the exact same problem, and ended up changing the cts... was the thermostat for me too :-)
    Audi A3 8L 1.8T Quattro 180 in black. Totally standard: for now...
    handy andy's Avatar
    Jul 2010
    75
    Danny
    Got it from TPS as recomended.Seemed expensive 26 ish +the dreaded VAT.That is a good price you where quoted...I should buy a couple to keep in stock fella.
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    292
    here you got mate, Audi A3/S3 Switches and Senders ive used them for years with no probs!
