JMB RetrofitsChris Nott
Thread: fault code help
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    fault code help
    hi guys,
    used my fault code finder today.
    found 3 faults.
    1, Maximum boost pressure exceeded - static no define (my car is only boosting at 5PSI)
    2, Engine coolent temp sensor (G62) - implausible signal P0116 (my car runs fine, fan kicks in when needed)
    3,Mixture adaptation - sporadic adaption limit (add) exceeded
    can anyone shed some light on these codes
    thanks Jay
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    S3 Paul's Avatar
    Oct 2006
    2,764
    I would say.... new coolant temp sendor first. and check the wires to it.
    The fan is controled by the rad fan switch ( fitted into the rad) so isnt linked.
    The coolant temp sendor has 2 jobs... 1 feed to dash temp gauge, other is a feed to ecu to tell it what temp the engine is.
    They fail on these engines quite alot,
    This could be linked to the mixture fault as it may think the car isnt upto temp .
    Clear the codes and see how it drives...then re scan for faults
    Noggy Blue 2001 S3
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    cheers mate. i did clear them, i will drive to work tomorrow. then scan again see if any come back
    ifso, will order a new temp sensor
    S3 Paul's Avatar
    Oct 2006
    2,764
    They are only around 15 if i remember right,
    Make sure you know which colour you have. one is green. one is blue
    Noggy Blue 2001 S3
