Volks AutosAH Fabrications
Results 1 to 13 of 13
    Apr 2010
    168
    attaching jetex filter to maf?
    whats the best weay to do this?
    Use a coupler to extend it a little - if so, what size diameter coupler will do?
    or just attach it straight to the MAF? if just straight to MAF - will the filter jand i just slide over the MAF and i can jubilee clip them together?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    jubilee clip straight onto the MAF
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    use a coupler and put it closer to where the standard air feed is. if u have an s3 it is 80mm to 80mm on an A3 its 80mm to 70mmi believe
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,069
    depends on which filter you've got mate.
    I got the 80mm filter, wanting to future proof myself if I upgrade to a 3'' MAF with a hybrid turbo.
    So I'm using the biggest jetex filter with the 80mm neck, then an 80mm alloy coupler, then an 80-70 reducer from Bill which takes it close to the wing.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    i have that same setup
    Apr 2010
    168
    it's an s3 i have guys, and the filter is 80mm i believe (its the one that bill supplies) so this means i won't be able to just slide it on if the maf is also 80mm
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by m8arx View Post
    YES it will fit straight on to your MAF
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    the MAF is 80mm and so is ur filter. it will fit but will be in the hottest part of ur engine pretty much lol
    higher1's Avatar
    Nov 2010
    isle of wight
    30
    mine is a s3 with the 80 mm filter fitted straight onto the maf with just the jubilee clip its a perfect fit
    18" RS6 reps / fk wheel spacers 15mm 20mm / revo stage 1 / forge 007 diverter / Jetex cone air filter / EBC red pads.
    Apr 2010
    168
    excellent - cheers folks
    Jul 2009
    520
    do you guys not find the filter vibrates a lot with the movement of the engine/car?
    I have heard strong vibrations can defect the MAF? is this true?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,069
    if you look at mine Liam, the filter is actually tight up against the original airbox mounting tab on the inner wing.
    It kind of sits under the top of the tab, which stops it rising, and I expanded the coupler right out putting the whole lot under tension before tightening the clamps so it's actually dead tight in there!
    Jul 2009
    520
    cool dude, i'll have to have a look.
    Off to protyre tomorrow for some new rubber
