EM TuningJMB Retrofits
Results 1 to 15 of 15
Thread: TD05 v VF34
    scoobyra's Avatar
    It's not f@cking ORANGE!!!!!
    Feb 2008
    Portsmouth
    803
    TD05 v VF34
    I'm getting really bloody confused with al this turbo nonsense and could really do someone pointing me in the right direction.
    Jabba are telling me they use a VF34.20 on their conversions which should be the turbo fitted to the black car that I've just killed. According to Jabba, they run at 1.6bar and are very (cough) reliable! only caused to fail by running aftermarket dv's.
    Cue TD05.....ok, so I have a TD05 16g which I'm going to convert (well I'm not, Andy Forrest is) to front entry and is exactly the same size as the VF34. Ideally, I'd like to run this as an 18g but I don't know if this will fit as the housing is larger.
    Jabba have said they couldn't get the TD05 to work as well as the VF34 unless it ran loads of boost (as if 1.6bar is low!) but I have conflicting reports from other people saying the TD05 will still spool quickly and make the same power as the VF34.20 even in 16g form.
    I've spoken to Bill (Badger5) and got his input so can anyone else add some reliable info to this as we (I mean Bill) are only going to do this ONCE as funds aren't bottomless and don't know whether I'm keeping the black car which puts the rods on hold for now.
    JAFFASPORT - 2001 Facelift, 218/237/216bhp AMK, Absolute Red, Thrashed to Death, Car Park Dents Everywhere, Kei Flux's, Knackered Shocks, Scuffed Rear Bumper and in need of a good Hoover!!
    BLACK EVO BEATER -2001 Facelift, 349bhp AMK, Ebony Black, Blue Seats, 4 Wheels, Brakes, Exhaust, Headlights, Sh!t loads of boost and up for sale!
    RGV 250N - Bloody fast and loads of fun........I get wet a lot when it rains....
    S3KO4's Avatar
    Aug 2009
    London
    850
    I have heared someone fitting, a TD05 20g to an a3 8l with custom mani. no actual proof at hand.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    803
    Should have also said.....it's going on the Jabba underslung mani!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    id let andy forrest do what he wants, he's not exactly bad with things impreza!
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    803
    I know Karl but this isn't on an Impreza. I really need to know how much bigger a TD05 18g is or a big 16g compared to the VF34.20 I've currently got as if I can go bigger than a standard 16g I will
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    i meant with impreza turbos lol.
    space is a massive issue on our carsa which is a shame.
    can you not find any dimensions on the net of both turbos?
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    803
    Been looking but it's a mine field. Andy says the 16g is exactly the same size as the VF34.20 which is good news but I'll go bigger if I can. He did say that it was possible to get an 18g wheel in a 16g housing but it would cost a fortune!
    RIP S3dave
    May 2004
    nr Glos
    7,175
    where the vf34 is described as .20, they have used the larger hotside off the vf22.. P20 housing, where VF34 comes in P18 as std
    not a lot in it tho... both are small housings which overheat quickly!
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    803
    Hot side meaning exhaust side Bill?
    RIP S3dave
    May 2004
    nr Glos
    7,175
    hot side meaning hot side, which is turbine side's housing to exhaust downpipe yes
    cold side is compressor side.. - inlet
    chra the middle bit where oil/coolant pipes and bearings/seals live
    and as for people saying vf34's can happily live at 1.6bar boost levels reliably, thats laughable, and said by someone who sells them to you...
    quicky searchy on vag forums reveals the truth about vf34's when pushed too hard
    bearings fail
    hotside housings warp
    its an ihi thing
    keep egts sensible, keep boost to sensible 1.2bar levels and they will work fine... ~300-320bhp/280lbft units
    want more, turn em up and prepare for replacing them, over and over again - thats reality
    www.badger5.biz
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,764
    Almost as bad as a hybrid !
    Noggy Blue 2001 S3
    S3 Paul's Avatar
    Oct 2006
    2,764
    K04 hybrid i mean.
    Noggy Blue 2001 S3
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by S3 Paul View Post
    worse imho
    k04's dont warp their housings, ihi's do not cope with 900'C temps, where k04's do
    www.badger5.biz
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,764
    I was talking to a lad from wakefield with the Jabba IHI set up on his S3 , He said things Are ok around 320 bhp but it wouldnt push much more. So i kind of decided the money he has spent was a bit steep with the same kind of power i have,
    Also he said the gearbox isnt removable with the turbo/ manifold in situ...?
    Noggy Blue 2001 S3
    RIP S3dave
    May 2004
    nr Glos
    7,175
    I totally agree with what he's said re power
    turbo underslung is a pita... remove transfer box tho.. if you can get at it.. and it should come off?
    www.badger5.biz
    bill@badger5.co.uk
