Results 1 to 17 of 17
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Question High pitched squealing on cold startup
    Howdo, anyone ever had a very high pitched squealing when they start their S3? It's like a slipping drive belt but it only lasts a second and then goes for the day, and it's also higher pitched. Car is garaged overnight so it's not as likely to be condensation on a pulley...
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by SiGainey View Post
    Check the serpentine aux belt for wear, and check the timing belt for wear mark would be my first place to start.
    Also may be worth spraying WD40 onto the aux belt and the aux belt tensioner pulley before first start to see if it alters the noise at all.
    Homer Simpson
    beachbuggy's Avatar
    Surrey
    1,745
    As Welly says.
    Spray WD40 on the aux belt and pulley, should temporarily fix the problem, if it does then it's a new belt and possibly pulley.
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    Could also be starter motor sticking slightly most vag 1.8t's suffer at sometime
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Timing belt was done not 6 months ago but i'll check it anyhow Could be the tensioner - the belt looks pretty new but they are only about a tenner so I'll chuck a new one on I think
    The alternator looks to have been replaced recently, so I doubt it's going to be that but it could be the air con compressor...
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    I started getting a squeel on start up on my S3 too. I think it is one of the belts this time, mine only happens if the aircon is on. I used to have a dodgy starter motor on my old A3 1.8T which also made a squeel bit it wasnt so high pitched, more of a torquey squeel if you get me, as the engine was doing work against the eletric starter motor, there was also the mechanical sound of slipping too.
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by S3BAM View Post
    Yeah, starter motor sticking is a squealy sound, but also mechanical. Normally happens every start though as it is caused by the solenoid sticking on, as opposed to just first start. Damn crappy VAG starters...
    Homer Simpson
    ptr
    ptr's Avatar
    Aug 2010
    129
    I've had this with the starter before, extremely loud noise, to the point it would make people jump if they were anywhere near my car when I started it
    Try WD40 as suggested above but otherwise is probably the starter sticking.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Does it do it if you have your aircon switched off?
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    I will check with the aircon off too - it starts about a second after the engine fires so it could be the starter motor disengaging...
    91
    I get it sometimes when I start the engine with the aircon on!!
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Sounds like your a/c fan is seizing.
    Mine has done this too.
    Replaced both of mine and the noise is cured.
    (i have a good - small fan here if anyone requires it)
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Yeah, its air con related started the car with the air con off, no noise. Drive for a minute, switch on the air con and the noise is there.
    Thanks for the advice all
    Nov 2010
    31
    Could be a pulley wheel. I had this on my BMW 520D a few months ago.
    Apr 2010
    Widnes Cheshire
    404
    Quote Originally Posted by ptr View Post
    My wifes A3 1.8 T has also started squeeling upon start-up just for a second, it does sound Starter Motor related to me.
    DC
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Quote Originally Posted by DenCar View Post
    DC
    Sounds aircon related to me
    Alex S3 AMK
    Aug 2010
    21
    its the starter motor.
    comon problem on our engines.
    check vortex =)
