Monster MotorsportChris Nott
Results 1 to 12 of 12
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    Stroud Gloucestershire
    122
    HELP! Boot Keeps Opening!
    After unlocking the car the boot opens?! I can hear the lock operating as if i'd used the boot open button by the number plate lights. Even if i get out and shut it the motor goes again and it opens again! This obvioulsy isnt good as the motor keeps persisting in opening the boot any time the car is unlocked including while driving.
    FOR SALE: 2003 RED Audi S3 - 73k - MINT - Custom-Code - Black Leather - £6600
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    122
    Will take the boot trim off and check the switches as maybe they are stuck on?
    19scotty81's Avatar
    Push down and across !!!!!!!!!
    Dec 2010
    Newcastle Upon Tyne
    107
    Check for water in the microswitch when you get the trim off !
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    122
    Thanks, will do.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yeah, common problem, something to do with the rear wash leaking iirc
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    122
    Connectors dont look too bad at all, there is a tiny bit of corrosion in each connector so have added a little WD40 to see if that helps.
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    122
    WD40 made no difference. Is it the plugs that play up or the actual switches as it looks like i will be replacing them?
    Did you solve this problem? Mine has started doing it today!
    Pete20vt's Avatar
    Supermoto Junkie
    Apr 2010
    122
    No all ive done is unplug both connectors to the two switches meaning that i can only open the boot with the key. Partly as i havnt had time to get to Audi and partly because im not sure what i should be replacing, switches or connectors?
    Same solution as me. Also I noticed my touch switched have stopped working guessing at the same time.
    Apr 2011
    I NEED HELP!!!!!!!!!!!!!!!!!!!!........ i have the exact same problem with my audi a3 Facelift model (2000-2003 shape).. the boot keeps poping open, and once its poped open, i can hear it still trying to pop open!! even wen its open! and it does it wen the car is stationary after being started up, and while driving!! What would cause this problem? can i fix it? DIY style?
    Nov 2010
    maidstone, kent
    53
    the easiest way to fix would be to replace both the switches and the plugs/pins. that way you get rid of all the corrosion and have fresh connections!
