Chris NottJMB Retrofits
Results 1 to 15 of 15
    ptr
    ptr's Avatar
    Aug 2010
    129
    Had the cambelt and waterpump changed for the first time at 97,000 miles...
    Previous owner never had it done so as soon as I had the funds got both changed, this is what is left of the factory pump, about a quarter of the impeller
    It still ran fine though, no overheating issues in summer and temp always sat at 90 or below. Replaced with a metal impeller water pump so shouldn't have any issues in the future.
    shanejess
    its nice feeling afterwards piece of mind. i had mine done at blackburn Audi, 622 pounds, timing belt water pump, major servive, new wipers front and back, oil and filter haldex service also not a bad price i thought.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    very lucky
    dany2k's Avatar
    Dec 2010
    Lancashire, England
    299
    lovely pic, should be a sticky for the dangers of not having your water pump changed!
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    lucky
    ptr
    ptr's Avatar
    Aug 2010
    129
    Just amazed that it ran fine like that, no overheating issues at all. Although I suppose it was only a matter of time before the last bit broke away and the temps went through the roof!
    Quote Originally Posted by dany2k View Post
    Cheers, took quite a few pics to make sure I did the damage justice
    Apr 2010
    35
    Mine was like this when I pulled it out the remaining bit just disintergrated, I would change your thermostat as mine got wedged open with plastic!
    ptr
    ptr's Avatar
    Aug 2010
    129
    Just after I had the cambelt done I had a wee crash and needed a new radiator, ever since the temp takes longer to reach 90 and sometimes just sits at 80, not sure if it's the new waterpump or rad thats made the change but do you think it could be the thermostat?
    bez101's Avatar
    Jul 2008
    8,525
    Quote Originally Posted by ptr View Post
    it could be the CTS
    scoobyra's Avatar
    It's not f@cking ORANGE!!!!!
    Feb 2008
    Portsmouth
    803
    CTS???
    JAFFASPORT - 2001 Facelift, 218/237/216bhp AMK, Absolute Red, Thrashed to Death, Car Park Dents Everywhere, Kei Flux's, Knackered Shocks, Scuffed Rear Bumper and in need of a good Hoover!!
    BLACK EVO BEATER -2001 Facelift, 349bhp AMK, Ebony Black, Blue Seats, 4 Wheels, Brakes, Exhaust, Headlights, Sh!t loads of boost and up for sale!
    RGV 250N - Bloody fast and loads of fun........I get wet a lot when it rains....
    ptr
    ptr's Avatar
    Aug 2010
    129
    Coolant Temp Sensor?
    Either way a new one is only a tenner from GSF so well worth replacing just incase.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    When I did my cam belt and pump I think I actually broke the pump removing it, its quite tight and if you don`t extract it squarely then Im sure it just breaks.
    red to red black to black blue to bits
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    My money's on the stat, mine was exactly the same, changed the stat now sits at 90 after 10 minutes and doesnt move at all. IIRC a tell tale of the CTS is a difference between the dash temp display and actual temp display shown on the heater controls and or fluctuating temp on the dash gauge.
    ptr
    ptr's Avatar
    Aug 2010
    129
    Quote Originally Posted by wibble111 View Post
    Cheers, just googled how to do that climate control trick and will try it next time I drive it.
    Also noticed yesterday the dreaded mayonnaise under the oil filler cap, praying it's just condensation and not the head gasket going.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Sounds like the thermostat to me....
    That's not typical symptoms of a CTS problem. Thermostat will generally cause temp to hang lower than 90 degrees. Does it get up to temp when left to sit?
    That's the acid test of this, if you can start it on the drive and leave it, and the temp climbs to operating temp as normal, then your stat is staying open for too long...
    Homer Simpson
