Chris NottJMB Retrofits
    Jan 2011
    6
    S3 misfire when cold
    hi there
    I recently purchased an 02 S3 with 80k
    when I viewed it at a garage and then collected it, they had ran it up to temperature which I now believe to be due to a mis fire when cold
    it goes once at temperature, I am suspecting coil packs??
    I had a full service done on her yesterday and the following fault codes came to light 16684, 16688, 16686, 16687
    Also, when really thrashing it, it crunches going in to third gear, any ideas??
    thanks for your attention to this and advice
    stu
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Full service including plugs?
    I would;
    - change the coilpacks & check coil pack wiring
    16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
    Possible Causes
    • Air Intake System leaking
    • Fuel Supply faulty
    • Injector(s) faulty
    • Ignition Cable(s) and/or Spark Plug(s) faulty
    • Ignition Coil(s) faulty
    • Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
    • Camshaft Position Sensor (G40) faulty
    Possible Solutions
    • Check Misfire Recognition
    • Check Air Intake System
    • Check Fuel Supply
    • Check Injector(s) and Injector Sealing
    • Check Ignition Cable(s) and Spark Plug(s)
    • Check Ignition Coil(s)
    • Check Exhaust Gas Recirculation (EGR) Valve (N18)
    • Check Camshaft Position Sensor (G40)
    Jan 2011
    6
    brilliant thanks mate, change all coils packs??
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    id take it back and let them fix it
    coil pacls will missfire hot or cold
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Crunching of the gearbox into 3rd is very common, most noticeable changing at high revs. An uprated dogbone mount(20 from powerflex) will reduce engine movement and make gearchanges more positive. Trade off is more vibrations into through the steering column from the engine.
    Jan 2011
    6
    thanks for your help guys
