Monster MotorsportVolks Autos
Results 1 to 11 of 11
    dubber dude's Avatar
    Jan 2011
    conwy north wales
    38
    steering angle sensor
    ive just replaced the steering rack on my 1.8t quattro, soon as i finished the esp light come on, i had it put on vagom and the fault code was the steering angle sensor !! it was suggested the steering wheel maybe on 360 degrees out , so i disconnected the steering uj turned the wheel 360 degrees . then the air bag light came on , so i had it put back on vagcom and got the following !!! could someone please translate for me and tell me how to rectify please !
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-A.lbl
    Part No: 1C0 907 379 F
    Component: ESP ALLRAD MK60 0104
    Coding: 0023046
    Shop #: WSC 01236 785 00200
    4 Faults Found:
    00778 - Steering Angle Sensor (G85)
    014 - Defective - Intermittent
    003 - Mechanical Failure - Intermittent
    008 - Implausible Signal
    005 - No or Incorrect Basic Setting / Adaptation
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 H
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00041
    Shop #: WSC 01236
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 5008
    Coding: 01104
    Shop #: WSC 01236
    1 Fault Found:
    00588 - Airbag Igniter; Driver Side (N95)
    32-00 - Resistance too High
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    surely you can reset?
    00778 - Ross-Tech Wiki
    Aug 2010
    1,540
    sounds like youve broken it by turning it the sameway too many times!
    did you look at the actual values thu the esp/abs for the steering angle to make sure which way it was out..... ie; plus or miuns the 360 degrees?
    Mar 2010
    Durham NE
    576
    yea, sounds like the clock spring is snapped.
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Jan 2011
    conwy north wales
    38
    i didnt no !!! i just presumed i could turn it 360 degs and poss recify it !!!...if im honest it just seemed like a simple job thats the only reason i took it on !!
    Jan 2011
    conwy north wales
    38
    Quote Originally Posted by AudiS3-Turbo View Post
    how can i rectify this ???? what is the clock spring ?? where is it ??? many thanks guys
    Mar 2010
    Durham NE
    576
    its the link/round connector that sits between the steering wheel and steering column,its the connections between the airbag as well as being a sensor for the steering ahead position,once its been overturned its scrap,new im afraid,they are pinned from new to not allow any movement until installed,then the pin is removed.
    If any steering work is carried out that will allow the steering column to turn free you should have clamped the wheel down or just put the steering lock on,if you dont know about it then you will never know mate.
    James
    Silver Audi 8L S3
    Jun 2010
    Just north of Durham
    32
    Changing the clockspring is a DIY job but you need to buy a new one or smart fitting a used one. The sensor can only be turned so many times in each direction but it does record when it's been turned more than 360 degrees.
    You need to remove the steeringwheel (marking on the splines with pen allows you to put it back on at the correct angle) then just pull the old one out.
    Fitting a new one is just a case of putting the wheels straight and refitting it.
    If your using a second hand one, put it in place then check abs measuring blocks for steering angle. it should be close to 0. if its 360 out just slowely turn the pin on the clock spring whilst checking the angle when its around 0,refit steering wheel and airbag.
    My last clockspring cost around 35 but thats around 5 years ago. 5 from ebay.
    Mar 2010
    Durham NE
    576
    to add to that you can reset the "0" deg in vagcom...you will probably need to after the new one is installed
    James
    Silver Audi 8L S3
    Jan 2011
    conwy north wales
    38
    cheers for the advice and feedback on this guys, i got a price from audi today 182.00 + vat !!! totally gutted !!! my own fault for not getting the advice first !!!
    Carpy25's Avatar
    Oct 2007
    272
    there's an inspection window in the top right hand corner of the clock spring to set it in the central position when fitting a second hand one new ones come locked in the centre with a clip
    i broke the first second hand one i got as well because i didn't centralise it correctly ,still needed vagcom to reset
    182 +vat is better than the price i was quoted mine was 200 +vat with discount
    Rob
