Badger5Monster Motorsport
Results 1 to 22 of 22
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    Loud boost leak sound
    Hi,
    for weeks now i have had this loud hissing sound when on boost. I know your all thinking boost leak.
    I have presure tested the whole system found my 007p leaks above 8psi but thats it. so looked at the intake pipe, I have removed the PCV return from the TIP and blocked this off the noise still there.
    removed the DV completely used bungs both sides, still the sound is there.
    Im running stock air box, it does it with both BMC filter and stock.
    Any help would be great?
    thanks
    Woody
    Chugger
    North Devon
    2,716
    maybe the tip is split?
    57 A3 2.0 TDI Sportback (140)
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    changed that too
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Where is the noise coming from? Which area of the engine bay?
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    from in the car it sounds like its coming from behind the glovebox if that makes sence
    g10chy's Avatar
    Jun 2009
    Crewe, Cheshire
    155
    My car does this...As far as im aware its completly normal and got louder after putting a green cotton filter and 007p on.
    2001 S3 - Ming Blue, Bose + AndyMac Stealth Sub + XCarlink iPod Interface with Bluetooth, Forge 007 (Yellow Spring), Green Cotton Panel Filter, Angel Tuning Remap, Milltek Cat-Back Resonated, Parking Sensors & Full Black Leather Nappa Recaros with Piano Black Trim.
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    My car never made this noise when i first bought it and it had a standard airbox. Green cotton panel filter made it a bit louder though.
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    no i dont think its normal i have been in other S3's and TT's etc that dont do it
    From Show... to GO
    Nov 2010
    Stafford
    436
    mine does it, its alot more noticeable since fitting my jetex and forge split R,
    sounds like its hissing out air under acceleration? that the same noise?
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    yes thats the noise a loud hiss just like a leak but my block 032 readings arnt bad at all
    Aug 2010
    bradford
    1,251
    my car does this 2 hissing noise when on boost one day it was quite next hissing on boost iv got newspeed and split r thourght it was turbo like ha
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    woody.dub's Avatar
    Jun 2010
    Essex
    98
    its horrid i really dont like it
    From Show... to GO
    Nov 2010
    Stafford
    436
    im not sure why it does it, i need to get a boost gauge in to see how it acts on boost.
    but it feels fine
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    I have this too but only in 4th gear +
    Ross_S4
    Aug 2009
    Dundee
    718
    not that i am doubting your pressure test mate but did you have the bumper off and test the flanges at the top and bottom collectors of the intercoolers? Mine burst here right at the top of the nearside intercooler at the flange between the finned cooler section and the top plastic collector section.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its possibly the turbo spooling?...mine is very loud, sounds like a shhhhhh sound
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Behind the glove box is the turbo/tip sort of area...
    Have you checked the turbo outlet pipe from the turbo to the charge pipe for starters.
    Failing that, and you are sure there are no leaks, check the actuator pipe for splits.
    Homer Simpson
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yeah good shout, with the turbo outlet to charge pipe being an orangey colour if it is leaking you will be able to see or feel for slight greasiness, like oil vapour
    Lloyd149's Avatar
    Dec 2009
    York
    102
    Try meet up with someone on here, see if their S3's have the same sound your experiencing. As said before, now i've got a Forge TIP, DV and panel filter, mines making more of the swooshing sound on spool up.
    Recently replaced my TIP, and found the original, at the turbo end. The jubilee clip was properly loose.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by woody.dub View Post
    What engine is it? And how bad is not bad?
    Homer Simpson
    Feb 2012
    54
    I have this loud hissing noise too and interested to know what it is!!
    marrick92's Avatar
    Jul 2011
    68
    I also have a loud hissing on acceleration, thought it was a boost leak but on my VCDS the MAF is showing bang on 10 g/s at 3000rpm??
