Sky InsuranceChris Nott
Results 1 to 10 of 10
    rob_sri's Avatar
    If in doubt, flat out
    Aug 2010
    125
    18010 - Power Supply Terminal 30: Voltage too Low ?!!!
    where would i find said Power Supply Terminal 30? any ideas on how to fix this?
    would rather like to get this sorted.. got two days off tomorrow and friday so im going to be having the beast apart!
    may have something to do with why my xenons are flickering before coming on
    already got to do my MAF, Stat, Temp Sensor, full oil change and have my passenger seat out for airbag connections! may as well do this at the same time!!
    S3 Stage 1 Map, Forge 007p, Jetex filter, JE Forged pistons and scat rods, ARP bottom end bolts + stud and nut kit fited with race ported head, 3" Downpipe + Full Ashley system, lowered on ebaich pro springs, white RS6's, HID headlights n fogs, dewipered..not bad for a few weeks modding .. Hertz Mille 3000 + Audison SR1DK, + coilovers coming soon!
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Have you disconnected the battery at some point?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    rob_sri's Avatar
    Aug 2010
    125
    nope! plus the fact my xenons flicker and give bulb out errors before they eventually come on by the 25th time i turn them on an off!! gets annoying! people think im flashing at them in car parks LOL
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    has the battery gone flat and also does it fire up first time in the mornings
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    rob_sri's Avatar
    Aug 2010
    125
    yeah usually first time even when its been freezing!
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    18010 /P 1602 / 005634 - Power Supply B +
    Terminal 30 : Voltage too Low
    Possible Causes
    Cables on the Battery were removed
    Battery weak ( voltage )
    Generator Disfunction
    Possible Solutions
    Check Battery Cables
    Check/ Replace Battery
    Check/ Replace Generator
    Special Notes
    If multiple Control Module have Power Supply
    Faults stored, it 's most likely to be one common
    Problem like the ones shown above. Otherwise
    when only one or two Control Modules have
    such Codes stored you better start searching at
    the individual Power Supply of these Modules .
    talentwalsh's Avatar
    May 2010
    Galway
    139
    Has your radio ever reset itsself. This fault appeared when my battery was on its way out, not fully dead but crank speed was slower than normal. New battery and bobs your uncle.
    rob_sri's Avatar
    Aug 2010
    125
    see its really odd like i put a volt meter on it today and it read 12v stood still and when the engine was running 14v and yet i was still having problems with flickering HIDs!!! they would flick on and then die and throw a bulb out error on the dash..again after a few clicks on and off they work fine?!
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    my rhs light does the same but its because I have replaced them with after market 6000k's, I turn It on off and back on and works for me every time
    May 2010
    Galway
    139
    Unfortunately using a volt meter will not tell you of a dying battery. Mine read 12.3 stationary and 14 running but was still buggered, you need a load tester to properly test the condition of a battery. Try find someone with a good strong battery (60 Ah or so) and try using it on yours (or jumping even, due to loosing radio codes and the likes) and see of the crank speed is noticably different.
    The flickering headlights are more than likely due to bulbs on the way out or dodgy balasts. Are they a bit pink or purple coloured
