Badger5JMB Retrofits
Page 26 of 145 FirstFirst ... 161920212223242526272829303132333676126 ... LastLast
Results 1,001 to 1,040 of 5799
Like Tree1060Likes
Thread: Prawn and BigAls A3 Track Car
  1. #1001
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,357
    haha, sorry mate, It was out of my text window so I forgot I ment to reply :P
    I did see an S4 that had the letters of his number plate cut out, that looked amazing. From a distance it looked like a standard plate, but up close, the characters were infact holes! how much air flow you'd get through that I'm not sure though.
    For your car, I'd probably think a few decent sized holes under the plate, along with corresponding holes in the crash bar would be the best you can do, then remove the plate for trackdays.
    Like you say though, if you're getting enough air flow into the core anyway, is it needed?
  3. #1002
    umop ap!sdn
    Sep 2011
    Havant
    33
    Quote Originally Posted by Westy View Post
    Nick are there any other options to get more air to the core?
    Intercooler ducting / air dams. Its the most efficient way of getting air to pass through the core as it creates a higher pressure of air infront of intercooler.
    Something like...
    You want to seal off the intercooler to the front of the bumper so all the air gets directed through the core and doesn't take the easy route of going round it.
    I do actually own an Audi...
  4. #1003
    umop ap!sdn
    Sep 2011
    Havant
    33
    Also to note, the image of the Saab - the intercooler could extend up behind the bumper, but so long as its completely sealed on all 4 sides, air WILL flow though the very top of the core, utilising the whole frontal area. No holes required.
  5. #1004
    May 2010
    Bedford
    2,877
    What about drilling holes behind the plate and in the crash bar and using brackets to space the plate a little way out from the bumper so it wasnt covering the holes completely and the air could get behind the plate through the holes?
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  6. #1005
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,272
    Trust me, even with my heat pump K04 running 22psi the inlet mani stays icy with just the lower grill to allow air in, I think all this hole drilling is a touch OTT.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  7. #1006
    May 2010
    Bedford
    2,877
    For a road car with massive cooler yeah. Plus does an S3 bumper have sliightly bigger grilles/openings than a normal A3 bumper?
  8. #1007
    Westy's Avatar
    Dec 2008
    17,272
    Quote Originally Posted by Jason.s View Post
    That could be a factor, different sized lower grill. But Even after an 8 lap session at Bedford last week the inlet was still cool when I came into the pits.
    S3 Build Thread
  9. #1008
    May 2010
    Bedford
    2,877
    Is that awesome huge core cooler :D Plus you have one of the better gaskets from Bill dont you?
  10. #1009
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Quote Originally Posted by Andy P View Post
    Something like...
    Bill and I have chatted about this before... might have a look at this in the new year... like the idea of it chaneling up the cooler behind the bumper too
    <tuffty/>
  11. #1010
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    my boss had a coarbon splitter on his race car, took it off because it was flexing at high speed and slowing him down, he then made one out of ply wood. think he's stuck with that since.
  12. #1011
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Plywood is remarkably good for things like that, it's light, stiff, and most importantly, cheap and easily replaced!
    Will be mounted on a proper frame though, after a chat with Andy today, something that will generate actual downforce, should not be mounted to a plastic bumper
  13. #1012
    S3 Paul's Avatar
    Oct 2006
    2,764
    Marine sp* plywood seems to be the choice of many... A friend races in time attack and alot of them seem to use it with alloy bracing/ mounts
    Noggy Blue 2001 S3
  14. #1013
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    yeh mounted as rigid as possible.
    will be interesting to know the differences you get from functional aero mods like a splitter and diffuser. its overlooked
    people just think 'il fit a big ass wing lad'
  15. #1014
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Well, seemingly, well thought out, properly built home made aero can be VERY good if you follow all the principles correctly.
    THis is a golf that belongs to a northloop member, it has a 2.0 16v engine with around 180bhp, and weighs just over 1000kg.
    As you can see, it's got a front splitter, full alloy flat floor with drop down side skirts, and alloy rear diffuser, and it's ALL home made in his garage.
    he goes around the Ring in 08:20 btg!
    It seems to stick to the road like no other golf in history, and all the bikers out at the ring say that the turbulence comming off the back of the golf is similar to that of a radical rather than a small hatch back.
    Proof if ever it was needed that home made aero can definitely work
  16. #1015
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    You're dead right Jase, the rear bumper basically acts as an air brake the way it come down and curves forward, air from under the car gets in there, and causes much turbulence.
    Holes in the rear valance would indeed help this, but the better solution, for smoother air flow, is to close the void up completely by adding in some form of flat floor., or a diffuser.
    I found this browsing ebay earlier:
    Fibreglass VARIS style universal diffuser diffusor | eBay
    Looks about perfect size for the A3. Might require trimming the spare wheel well down, but I could probably remove that all together if needs be. Thats something for the future though, once the new turbo is finally on!
    Was also looking at the possibility of making up my own front splitter, you can buy stabiliser bars for a splitter fairly cheaply, and make make the splitters from something simple like 6mm ply wood, as it's strong, stiff, and very light. Could be a cheap project to try over winter!
    Do you reckon that diffuser would fit under a s3? would look the nuts.
  17. #1016
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    im of the impression that anything can be made to fit just about anything if you want it to Dani, so yea, I reckon it could be made to fit!
  18. #1017
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    i like your thinking nick . Think ill see how you get on first though as at over £100 i have other stuff to be buying first lol.
  19. #1018
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    yeh. you just need to have as little clearance at the front, and a large flat diffuser at the back sloping upward. low air pressure ftw
  20. #1019
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Does he trailer the golf? or is the aero removable as it looks like it would catch on speed bumps and not be easy to drive on uk roads
  21. #1020
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    the golf IS road legal, but I think it only ever goes on the road for it's MOT and things like that, it's only kept road legal for use at the Ring I believe.
    Nige's aero is pretty cool though, the side skirts you can see are actually rubber strip, the alloy part is only about 50mm deep, then the rest is made in 10mm thick rubber clamped to the alloy, which hangs down almost to the floor to create the ground effect, this wears out as it rubs along the floor, and every few trackdays he has to replace the rubber! Very clever idea I thought.
    He's also got little steel blocks under the corners of his splitter to act as skids after he kept grinding away the splitter.
    i don't think I'll go that far, but a home made splitter is definitely going to happen, coupled with a small diffuser I think
  22. #1021
    Westy's Avatar
    Dec 2008
    17,272
    You wouldn't want to hit a puddle in that thing would you
    S3 Build Thread
  23. #1022
    May 2010
    Bedford
    2,877
    Just read half of his thread. Thats some serious reading and some serious work gone into that car. I love the pit in his garage floor!! I want!
  24. #1023
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    really interested in the aero design for the A3. can't wait to see it put into plan
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
  25. #1024
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    does this mean the lcr splitter will be going?
  26. #1025
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Noooooooooooo, the new splitter will sit flush with the bottom of the LCR splitter, which, lets me honest, is more of a 'lip' than a splitter.
    The A3 bumper slopes up loads as it comes forwards, so attaching a splitter at the lowest point would leave a wedge to trap air. Leaving the LCR splitter in place fills this wedge nicely.
    The splitter will be solid mounted to the chassis via the subframe and crash bar, and the bumper will be removable leaving the splitter in place
  27. #1026
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    does that Nige fella with the golf use an mx5 there too?
  28. #1027
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Not that I know of Karl, Nige has been developing the golf for years now, hence why it's so extreme!
    Hullavington trackday booked for Andy and I, so the A3 / S40 show down we've been after will go ahead next Friday! can't wait.
    Also, in other news, I'm going to rig up some brake cooling ducts this weekend to ensure the brakes stay cool, I've not had any trouble with overheating yet, but it can't hurt to add some cooling in, especially if we're planning on doing some extended track sessions.
    It's even colour coded too!
  29. #1028
    Westy's Avatar
    Dec 2008
    17,272
    Where will you put the ducting mate and how big do you think it will need to be to have any real effect on cooling?
    S3 Build Thread
  30. #1029
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Well, I've been looking into brake cooling a bit, and it's not the sufrace that you need to cool, it's getting air to the centre of the bell so it can come out through the disc that really helps cool it down.Apparently the vanes in a vented disc are shaped so that they draw air from the inside of the disc and it passes through between the two plates, and out on the outter edge.
    I'll run these ducts, 60mm diameter, from the front bumper to the wishbones, then out along the lower wishbone and point them at the centre of the disc. I'll also remove the splash guards too.
  31. #1030
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    A few pics taken by Warren_cox at ADI, thanks for these mate!
    Will be getting the car ready for Hullavington this weekend, I'm making up a DIY camera mount for the cage, oil and filter change, and fitting some brake cooling ducts to help keep temps down.
  32. #1031
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    Whens BBD coming to pick up these wheels foostick?
    I quite often say I'm going to do things.
    Then never do them.
  33. #1032
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    When they're home dude, they're currently here, as seen on this handy webcam!:
    Those of you who know the location will likely be very jealous
  34. #1033
    Westy's Avatar
    Dec 2008
    17,272
    Ah man, they at the petrol station round the corner from the ring
    S3 Build Thread
  35. #1034
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Yup, in the Polo of Win! check out the 16'' Audi rims
  36. #1035
    warren_S5's Avatar
    Oct 2007
    7,158
    Pleasure mate; maybe get some better ones next year if I remember to take tripod!
    Audi S5 3.0V6T Coupe Black Edition
  37. #1036
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Can't wait for the video of the trackday prawn.
    What's the octane level at that petrol station?
  38. #1037
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    its 102, its mental!
    edit; hang on, it might not be, i cant remember now
  39. #1038
    Reesy's Avatar
    East Sussex
    3,604
    That is the first car I have seen that those 16's actually suit..
  40. #1039
    Westy's Avatar
    Dec 2008
    17,272
    The petrol station in the pic above isn't the one that sells the 103 rocket fuel. That's down in Adenau.
    S3 Build Thread
  41. #1040
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,357
    Eds only does 97 Super I believe, although Aral in Adenau does 102, which is basically BP ultimate 102.
    Amazingly, the 102 in adenau is the same price as Eds 97! Well worth the drive
  1. Various "Races" and competions using company cars
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2005, 17:58
  2. im back... and so is my car
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2005, 11:36
  3. Help me for my project - Track car
    By StephaneS in forum General Chat
    Last Post: 4th February 2005, 16:23
  4. pics and update of my car
    By pd130a4 in forum Diesel forum
    Last Post: 29th October 2004, 14:55
  5. Insurance and warranty with track days
    By StephaneS in forum Major UK Events
    Last Post: 8th September 2004, 09:24
