Chris NottEM Tuning
Page 23 of 146 FirstFirst ... 131617181920212223242526272829303373123 ... LastLast
Results 881 to 920 of 5811
Like Tree1062Likes
Thread: Prawn and BigAls A3 Track Car
  1. #881
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,364
    and yes, the engine loom does unplug fully just like an A4 mark, everything runs to a single plug on the ECU via a big fat bulk of loom that spreads under the battery.
  3. #882
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    no, because your cluster doesnt support the level sensor, so you could just leave it disconnected. On the A4 the cluster has an oil temp gauge, which uses the same pin as the level sensor uses, so mark for instance will have to modify his loom to connect the level sensor wire to the old temp sensor.
    The A4 platform went IMMO3 around february 2000, i'd imagine A3 would be similar.
    TD5 Land Rover Defender build
  4. #883
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    ah, that's cool. I wasn't sure if the level sensor was linked into the pressure warning alert, I've never had the level warning come on in my ME7.5 daily A3.
    What sort of time frame are you guys running on currently? is this something you're hoping to have done soon? or long time work in progress?
    I need to make a decision fairly soon, as rob wants to get the rest of the car sold, and he's holding off selling the engine with the loom incase I want it!
  5. #884
    "Stick a V8 in it!"
    15,372
    Mark has everything sitting ready to go, and is afaik just waiting on some time to finish up the boost pipes/map sensor fitting and then sorting out some mapping time.
    For me it'll probably be a few months. I have the harness, throttle body and pedal assy, but still need to find a MAF, ECU, Map sensor, injectors and wideband lambda for muchos cheapness.
    Plus dawns motor needs some front arms and springs slightly more urgently than i need an ECU upgrade, so those will be coming first!
  6. #885
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    argh. I just don't know!
    Would I need to change my bolt down hitachi coilpacks for later push down style unreliable ones? Mine currently are controlled by a seperate ign amp, so I guess I'd need the ME7.5 coilpacks too.
  7. #886
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Hitachi bolt downs are amp included coil packs. I use them after changing my current loom to lose the amp.
    I may go to FSI ones once Bill has done the testing and the gains are proven.
  8. #887
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    hmmmmmmmmmmmmmmmm, perhaps mine arn't hitachi then, mine are bolt down on an AGU, but it definitely has a seperate amp.
    So much to think about, I'm wondering if I'm not better off with an EBC to control boost, and having it mapped on ME3.8.
  9. #888
    Apr 2004
    12,520
    No ideas mate. I am just awaiting the opertunity to get my IC pipes re made and the sensor boss added. then it's all systems go, nail the gt28rs on at the same time. So even while chugging around at actuator pressure it should have a little summat
  10. #889
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Federal Tyres, how do you rate them Prawn?
    Wear
    Grip
    Noise
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
  11. #890
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    could you run a switchable map with an mbc. one setting for reliability and track use, and another just because you can lol. just do the switch then turn up mbc.
  12. #891
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So would this ECU swap be possible on my non-wideband APY s3?
  13. #892
    "Stick a V8 in it!"
    15,372
    if your already DBW then its just a case of swapping the ECU and adding two extra wires for the wideband lambda sensor (and possibly a resistor for the ECU's VVT output)
  14. #893
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yeah its DBW, instead of a resistor for the vvt, could i just fit it?
  15. #894
    Reesy's Avatar
    East Sussex
    3,604
    Right slight thread Jack. I had a tqs with a map, i now have a tqs without a remap, but my other one is coming back to me (it was written off). the written off one was a 2000 'x' facelift and the new one is an 02. could these be swapped over, and a program like vag tacho be used to change the mileage...
  16. #895
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    So, I actually did a small amount of work on this today, not much, because I spent all morning mopping Tori's Polo back to super shiney red, but I got an hour in this afternoon on the wheel, I also nipped up to the paint shop this morning and had the colour on the other 3 rotas matched, closest match we could find was Mazda Driftwood 11B, shade 104a.
    Take one brand new rota Force, in Hyper black
    Attack with 600 and 800 wet and dry, and lots of water, for about 45 minutes, then clean thoroughly:
    Apply first few coats of paint
    Then after another coat of paint, I called it a day, as it was getting too cold and humid to paint any more.
    Up against another wheel, it's not a bad colour match at this stage, and should get better once I get a few more coats of colour, then a few coats of laquer on:
    I also popped into Storm Developments to say hello this morning, and met Alex, although, at the time I didn't realise you were on here! Sorry mate. No wonder I looked confused when you said you'd read my build thread!
  17. #896
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    Finished, colour match is great too:
    Being fitted at 12
  18. #897
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Look ace mate.... good job...
  19. #898
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    So, I'm sure you've all seen these pics in my Tripod thread, but here they are again, just to keep the build thread up to date.
    Rotas fitted:
    This is the one we painted, it's actually mazda driftwood, not rota bronze. I don't think you can tell at all now they're on
    And of course, that bloody volvo that keeps appearing in my thread, it's back!
    The drive is transformed with the Rotas on, the car feels much more nimble, quicker to change direction, more steering feel, it rides better, and it's slightly quicker off the mark too.
    All round general win then!
    The style and colour might not be to everyones taste, but they're Rotas, so they had to be bronze, and I love them!
  20. #899
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    i think they look superb mate.
    the bronze suits it. it breaks it up. black would've been too much imo, too plain.
  21. #900
    umop ap!sdn
    Sep 2011
    Havant
    33
    It'll keep appearing in your rear view mirror on the next track day too. You might be faster, but you're not going to shake me off easily
  22. #901
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    The wheels suit the car well, I didnt think they would when you first posted what you'd got, the colour works well too, I think you should paint the calipers bronze like the GTR/350Z ones
  23. #902
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    Cheers man! calipers, and rear arb now it's so visable, will be painted orange I think
    May have just bought something else for it as well, but I'm waiting on confirmation before I post up about it. Hoping they're not sold already!
  24. #903
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    Since removing the welder and 80kg of TT rims from the boot, it sits much better, and I'm absolutely LOVING the rotas now.
    Feels so great to drive too
  25. #904
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    so, whats next? is there anything left to do?
    oh you gotta fit that ko4 havent you!
  26. #905
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    Not a huge amount left to do really Karl, but there's always development to be done.....
    The CR KO4 hybrid has to go on at some point
    But that costs time, and money, so it can wait for now until I'm good and ready.
    Aside from that, not that much more to come really. I'd like to get it lighter, the aircon has packed up recently, so rather than fix it I think I'll just remove it, I'd like perspex rear windows, and perhaps a bit of weight saving elsewhere
    the closer to 1000kg it gets the closer we should end up at the magic 300bhp / ton figure
  27. #906
    RIP S3dave
    May 2004
    nr Glos
    7,173
    like ickle lupo
    S3's in its dust/tyre smoke
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  28. #907
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    That's the plan Bill!
    I'll be honest, having priced it up, it's looking unlikely I'll be able to do the ME7.5 conversion. it'll make Bobs engine that much harder to sell, and given everything else I still need, I can't afford to pay him good money for the bits.
    Is the ME3.8 something you can still map? Boost control will be an EBC with solenoid in parallel to the N75 so I can have a few different outputs.
  29. #908
    May 2010
    Bedford
    2,877
    Yeah and its this bloody Volvo that has me trauling through the Volvo forums and pistonheads looking at T4`s to buy and mod! grr lol
    Wheels are looking sweet though. Not many people outside of the jap world go bronze but the colour looks so good on a lot of wheels!
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  30. #909
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,066
    Visit 16Klappe's Instagram Channel
    That one wasnt even a T4
    I quite often say I'm going to do things.
    Then never do them.
  31. #910
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    Tiz now though. I'd post up some pics of the original S40 if I had any, perhaps Andy can contribute?
  32. #911
    May 2010
    Bedford
    2,877
    i`ve seen his old rwd project on Driftworks that he then scraped in favour of the S4 shell. Problem is finding a decent tuner for them Some people are even going to Holland to see Rica just for a custom tune. MTE which he has on that one ^ is about the best for big turbo apps but dont know how easy that is to really aquire in this country. Its a bit like the A4 currently..proving to be a pain for tuning any further than a basic stage1 and even then finding someone decent is hard.
  33. #912
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Looks awesome dude!
  34. #913
    umop ap!sdn
    Sep 2011
    Havant
    33
    Quote Originally Posted by Jason.s View Post
    Bit of a forum junkie like myself then? :P
    A random selection of pics of the old car....
    Oh I miss it....
    I do actually own an Audi...
  35. #914
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I'm trying my hardest to keep my car up with your project but you just dont stop do you
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  36. #915
    umop ap!sdn
    Sep 2011
    Havant
    33
    And Nicks favourite car of all time...
    Just raped your thread Nick. Unlucky...
  37. #916
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    now THAT ^^ is awesome!
  38. #917
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    Latest addition: lightweight Road wheels / wets to save wearing out the RS-R's during normal road use.
    These wheels will be going on it for road use, Oz Racing Superturismo's in 8x17 ET35, currently shod with Pirelli Asymetrico tyres (seen here on the Bora of Win)
  39. #918
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Wheel whore!!!
    (luvvin yer work btw ;P)
    <tuffty/>
  40. #919
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,364
    they came up at a really good price Paul, and we DO need some road wheels to stop wearing out the RS-Rs, so it seemed like a sensible choice
    Now, time to stop messing about with wheels (have 4 sets now) and make steps to get this turbo on!
  41. #920
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    ...Now, time to stop messing about with wheels (have 4 sets now) and make steps to get this turbo on!
    Get it done!!!
    <tuffty/>
  1. Various "Races" and competions using company cars
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2005, 17:58
  2. im back... and so is my car
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2005, 11:36
  3. Help me for my project - Track car
    By StephaneS in forum General Chat
    Last Post: 4th February 2005, 16:23
  4. pics and update of my car
    By pd130a4 in forum Diesel forum
    Last Post: 29th October 2004, 14:55
  5. Insurance and warranty with track days
    By StephaneS in forum Major UK Events
    Last Post: 8th September 2004, 09:24
