- Joined
- May 28, 2004
- Messages
- 10,217
- Reaction score
- 2,385
- Points
- 113
- Location
- nr Glos
- Website
- www.badger5.co.uk
okies...
tests from today on stage 1 map from rtech on an s3 of danes.
car has no mods at all.. aside from rods i fitted for its upgrade path planned by the owner Dane
before any change, run on dyno on its std airbox and silicon tip, with k&n filter element. airbox had been drilled with big holes in its base by previous owner.
logs:
then 3 inch tip ws fitted along with the FR08001 filter
dyno'd again... no other change
bolt on g/s gains of from an intil best 196.14g/s to 215.28g/s = gained 19.14g/s of airflow
and the before & after dyno is.....
Pretty conclusive to me... and I was surprised to be honest in the difference.. on stock k04, on a stage 1 map, with no other performance mods on it, just changing the tip's and filter. wow!
Also, after this we did some playing with the mapping to see if there's any more left in it, for its lack of mods.. so did a custom map for it.. and eaked a little more bhp out of the girl.
comparison below of silicon tip, rtech stage 1, 3inch tip rtech stage 1, and a Badger5 map on it
This has ended up the most powerful std k04 car i have run so far on my dyno..
started with 251bhp from its map, then rose to 270bhp on that same map but with 3inch tip, then to 278bhp with some tweaks
There was no side effect to installing the 3inch tip on th stage 1 std k04 turbo at all... just more airflow and top end sustained torque = more power.
Well please with this result. surpasses my expectations
...in stock to buy folks
logs:
Code:
Saturday 18 December 2010 11:43:30:61786 VCDS Version: Release 10.6.3 Data version: 20101206
8N0 906 018 J 1.8L R4/5VT 0004
Group A: '002 Group B: '020 Group C: '115
RPM Load Inj. On Time Mass Flow Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Absolute Pres. Absolute Pres.
TIME TIME TIME
Marker STAMP /min % ms g/s STAMP °KW °KW °KW °KW STAMP /min % mbar mbar
409.24 1520 85.7 8.16 27.28 408.52 0 0 0 0 408.83 1520 80.5 1640 1100
410.35 1800 94.7 8.84 33.89 409.63 0 0 0 0 410.04 1680 92.5 1690 1200
411.45 2320 121.1 12.24 57 410.73 0 0 0 0 411.07 2160 108.3 2250 1350
412.66 2840 172.2 17.68 104.86 411.86 0 0 0 0 412.27 2680 146.6 2340 1830
413.89 3400 190.2 19.72 127.64 413.07 0 0 0 0 413.49 3240 185.7 2340 2320
415.08 3920 191 19.72 142.39 414.27 0 0 0 0 414.67 3720 190.2 2340 2310
416.31 4400 188 19.72 157.31 415.48 0 0 0 0 415.89 4240 188.7 2330 2320
417.49 4880 183.5 19.72 172.33 416.71 0 0 0 0 417.09 4720 186.5 2310 2300
418.69 5320 176.7 19.38 181.17 417.89 0 0 0 0 418.31 5160 180.5 2340 2220
419.91 5760 173.7 19.38 188.36 419.09 0 0 0 0 419.52 5600 172.9 2340 2190
421.1 6160 163.2 18.02 190.53 420.31 3 0 3 0 420.7 6040 166.2 2290 2110
422.34 6600 155.6 17 196.14 421.54 3 0 3 0 421.92 6440 157.9 2210 2090
423.53 7000 145.1 15.98 193.72 422.75 3 0 6 3 423.11 6880 148.9 2080 2020
424.77 7040 26.3 1.02 4.89 423.93 3 0 6 3 424.32 7240 128.6 1530 2260
Code:
Saturday 18 December 2010 13:36:18:61786 VCDS Version: Release 10.6.3 Data version: 20101206
Group A: '002 Group B: '020 Group C: '118
RPM Load Inj. On Time Mass Flow Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Temperature Load Absolute Pres.
TIME TIME TIME
Marker STAMP /min % ms g/s STAMP °KW °KW °KW °KW STAMP /min °C % mbar
153.79 1720 40.6 4.08 13.56 154.11 0 0 0 0 154.52 1560 15 0 1020
154.9 1600 45.1 4.42 13.83 155.33 0 0 0 0 155.7 1640 15 92.5 1060
156.11 1640 82.7 7.82 27.97 156.53 0 0 0 0 156.92 1640 15 94.5 1200
157.32 1760 93.2 8.84 32.92 157.74 0 0 0 0 158.14 2120 15 94.5 1370
158.53 2320 126.3 12.58 60.11 158.92 0 0 0 0 159.34 2680 15 94.5 1940
159.72 2880 187.2 18.7 106.94 160.04 0 0 0 0 160.43 3200 15 83.5 2110
160.85 3360 178.9 18.36 116.39 161.26 0 0 0 0 161.63 3680 16 83.1 2130
162.03 3880 186.5 18.36 138.17 162.46 0 0 0 0 162.84 4200 17 83.9 2160
163.16 4320 188.7 18.7 155.36 163.56 0 0 0 0 163.94 4640 18 87.5 2180
164.29 4800 191.7 20.06 177.11 164.67 0 0 0 0 165.06 5120 21 87.5 2210
165.48 5280 191.7 20.4 194.58 165.87 0 0 0 0 166.28 5600 24 93.3 2260
166.67 5720 190.2 19.72 208.86 167.08 0 0 0 0 167.5 6000 27 92.9 2250
167.88 6160 183.5 19.04 209.19 168.29 0 0 0 0 168.69 6400 31 94.5 2190
169.1 6520 174.4 18.02 215.28 169.51 0 0 0 0 169.93 6800 36 87.8 2120
170.32 6960 159.4 16.32 210.36 170.72 0 0 0 0 171.12 7200 39 74.1 2100
