EM TuningSky Insurance
    Nov 2004
    23
    HEADLIGHT PROBLEM!!! HELP
    My front left headlight was misaligned so I took it in to my Audi dealer, they called me back and said there was something either loose or broken inside the headlight, but they could not take it appart because it was glued together, and in order to open it, they would have to damage some parts, and they couldnt order those specific parts. Sooo they suggested to REPLACE the whole headlight unit for... $1,400 dollars!!! Just because there is something wrong inside! the adjustment knobs do turn, but the light does not go up or down!! HELP I really want to get these problem fixed, and I dont have $1,400 dollars to spend on a headlight. I heard some people heat the headlight unit in the oven in order to open the headlight. Any thoughts on how to get the headlight open??? Thanks
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: HEADLIGHT PROBLEM!!! HELP
    Yes you can heat up the sealant for the glass to remove it, but I'm sure the adjustment workings with be within the plastic part at the back of the light.
    I guess all you can do is see if it all comes apart.
    Failing that, send an email to a UK or european breakers yard and get them to send you a second hand unit which will be a fraction of that price.
    Also keep an eye out on ebay.
    Nov 2004
    23
    Does anyone know how to remove the headlight from the car?
    PaulS3's Avatar
    UK
    988
    headlight removal is a bumper off job i am afraid, then its only a matter of 3 screws (i am assuming its a one piece facelift headlight..)
    modern headlights are not meant to be taken apart, thats why the dealer is saying it is glued, it is. The lense is never meant to be removed.
    even heating it up, it will never go back on and be waterproof again.
    if the headlight is "not going up or down" with the adjustment screws, its quite likely that they have been wound so much, its come off the adjustment screws.
