Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Dec 2008
    29
    Audi S3 ABS Control Module knackered
    Hi,
    I have been told by my mechanic that my ABS control module needs replacing, it was sent off for testing this week and they have been told its unrepairable.
    I've been given 2 options:
    1) Fork out for a new one @ ú1000+
    2) Try and find a 2nd hand or refurbished one which should cost arond ú350
    Does anyone know where I can get a refurbed one?
    I googled it and the S3 ABS modules seem ultra rare at the moment, the part number is: 8N0907379E
    Hope someone can help
    Mike
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    there is a couple of s3's being broke on ebay at the moment, worth ringing them up.
    09 white black edition a3 2.0 tdi ­čśâ
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    Dec 2008
    29
    Thanks Mpathe,
    Will have a look.
    Dec 2008
    29
    Has anyone ever had to get there ABS module replaced. I've been calling around most of the ECU/ABS testing companies to see if they have one available to no avail.
    All they seem to do is repair them.
    I'm a bit stuck as to what to do, should I just get a new one? What is it likely to cost me?
    Mike
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    ebay breakers
    Dec 2008
    29
    Managed to find one on Ebay Germany.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    sorted!
    thorsy22's Avatar
    Jul 2008
    West Sussex
    307
    Yes mine was that module, got the module and pump from a guy on ebay that was breaking an S3 for ú100.
    Other place is BBA-reman or something like that, think they are based in Rochester think they quoted ú350/ú400 for a second hand one if they could get hold of one.
    Unfortunately you can't just take the module off the pump due to the way the brake pipes run under it, its a pump out and then take the module off the pump when out. You also need a special socket to remove the module from the pump, iirc its called an E-torx basically a 6 star torx socket.
    If you have access to vag-com and can still talk to the module take a note of the coding incase you need to change it in the new/replacement module.
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
